Thread: RPM/ Power Fluctuation under load
Results 1 to 8 of 8
  1. #1 RPM/ Power Fluctuation under load
    Michigan
    I have a 99 Grand Prix GT with 186k. I get an engine fluctuation (1900-2300rpm) when its under a load such as trying to increase acceleration from a steady cruising speed. The occurs at 1900-2100 rpm & a speed of about 55mph. It takes an increase of the gas pedal, to make it stop going up & down (tach needle) of approx. 2600-2800 rpm & a speed of approx 65 mph or getting on a level road which eliminates the load/ drag on the engine. Could this be a MAS/MAF problem?
  2. #2 Re: RPM/ Power Fluctuation under load
    sounds like a TCC lockup issue. let off the gas completely to unlock the TC, then ease back into it and it shouldnt do it.
  3. #3 Re: RPM/ Power Fluctuation under load
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    x2 on lock up issue
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  4. #4 Re: RPM/ Power Fluctuation under load
    Michigan
    Is there a way to fix the problem permanently if it is a TC problem? I push the TC button on the dash to turn off the TC and it doesn't change.
  5. #5 Re: RPM/ Power Fluctuation under load
    Jan 1970
    Maquoketa, Iowa
    Torque Converter
    Traction Control
    It sounds like a problem with your torque converter, which is between the engine and the transmission.
  6. #6 Re: RPM/ Power Fluctuation under load
    Jul 2008
    sumter,south carolina
    torque converter clutch solenoid can be goin out... get it scanned for codes.
    02 GTP with mods 05 GP for DD
  7. #7 Re: RPM/ Power Fluctuation under load
    Jul 2010
    Yea i get the same problem on my 00 GT. But it only happens occasionally. I usually just push the gas down until all of a sudden im slammed into my seat from all my horses letting go . But really the only way to make it stop sputtering is by giving some gas until it does a small "jump" of acceleration.
  8. #8 Re: RPM/ Power Fluctuation under load
    Pennsylvania
    Vacuum leak or clogged valve body? Vacuum leak is cheaper to fix, so trace all your lines. A scan would help with this... they're free from auto stores.
  1. Bogs under load
    By inition in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-17-2010, 04:53 PM
  2. Stalls under load.
    By reem82 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-06-2009, 11:52 PM
  3. No power under load
    By workingpoor in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-14-2009, 04:02 PM
  4. Oil Pressure Fluctuation
    By blueguy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-22-2009, 03:06 PM
  5. Temp fluctuation
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 10-11-2008, 08:28 PM
