Thread: Type of fuel
Results 1 to 11 of 11
  1. #1 Type of fuel
    SE Level Member KitRae's Avatar
    Jul 2012
    St. Catharines
    Ok. First, sorry if this has been asked already.
    I have a non-mod 02 GP GT n/a 3800. Just wondering if running 89 (low grade) fuel would hurt the engine or should i nnot even worry about it?
    Sent from my GT-S5690M
    2002 Grand Prix GT 3.8L Naturally Aspirated
    - NGK Iridium Performance Spark Plugs
    - NGK 51031 Performance Spark Plug Wires
    - EPR Cross Drilled Performance Brakes & Ceramic Pads
  2. #2 Re: Type of fuel
    Just run 87 octane
  3. #3 Re: Type of fuel
    87 is gas is takes from the factory, running anything else is 100% okay.
    It doesnt matter what you want to run, a higher grade will just reduce some ping/knock retard at full throttle.
  4. #4 Re: Type of fuel
    I live here. DirtDog's Avatar
    Jun 2012
    Run 100 octane. Rackar
  5. #5 Re: Type of fuel
    Jul 2012
    Chicago
    You can run 87 without issues.
    -Carl
  6. #6 Re: Type of fuel
    GTP Level Member
    springfield IL
    I've always wondered if the gas stations really have diff octanes like the pump says they do.... How could you tell if you get 93 octane for the 30 cents more your paying...??? Lol.
  7. #7 Re: Type of fuel
    Jul 2012
    St. Catharines
    Always wondered that myself. Dirty little bastards if it is all the same. Lol
  8. #8 Re: Type of fuel
    Jun 2012
    Quote Originally Posted by tc300 View Post
    Quote Originally Posted by KitRae View Post
    My motor can tell the difference and so can urs. They really have different levels.
  9. #9 Re: Type of fuel
    if you run 93 in a n/a engine it should get better mpg, not a whole lot but better. and feel a bit stronger.
    but running 87 is safe cause your n/a.
  10. #10 Re: Type of fuel
    Jun 2012
    Exactly. But run 87 in a S/C or ls4 motor without being tunes for it ...then beware
  11. #11 Re: Type of fuel
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    The EPA (I beleive its the EPA or some GOVT agency) comes around and randomly tests the flow of pumps for acuracy and also test the fuel quality to make sure it is the same octane it is claimed to be and also tests to make sure the detergents claimed to be in the gasoline are there. (BP-Invigorate, Marathon-STP, ect)
    I went NA when a whore left -$300 in my bank account.
  1. What type of amp?
    By MattF in forum Audio, Security & Visual Electronics
    Last Post: 02-23-2013, 03:33 PM
  2. Type of gas
    By aray590 in forum General Tech Discussion
    Last Post: 03-26-2012, 12:23 PM
  3. GTP vs. GTP vs. CL type R vs. G35
    By wpbboy81 in forum Track Sessions and Kills
    Last Post: 09-22-2011, 08:59 PM
  4. 04 RSX type-s
    By 99prixgt in forum Track Sessions and Kills
    Last Post: 12-08-2008, 10:05 PM
  5. what type of intake??
    By 99prixgt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-01-2008, 03:46 PM
