Thread: Crankcase vacuum?
Results 1 to 6 of 6
  1. #1 Crankcase vacuum?
    Twin Falls, Idaho
    Hi all!
    I picked up a 1999 Grand Prix GT about a month ago. Been going through it & fixing the little stuff, as well as doing intake gaskets & replaced the upper plenum (was starting to rot through where the coolant passages are). Did a full tune-up (plugs, wires, all filters, all fluids).
    Now my problem is that the car is producing a HUGE amount of vacuum in the crankcase. If I pull the oil fill cap off (& I really have to pull), the car will die 9 times out of 10. The 1 of 10 it stumbles bad but stays running.
    This is something I have yet to run into, so wanted to ask first if anyone else has had this issue. Could it be head gaskets? Or even the lower intake gaskets somehow? It runs smooth, has plenty of power & has no CELs or Codes showing up on the scanner.
    I'm currently not driving it until I have time to fix it, as I don't want to make things worse, whatever the problem may be. The lower intake gasket set is the newer FelPro design (metal with molded rubber).
    Sorry for the long post & thanks in advance! I'll answer any questions that may help me figure this out.
    Greg.
  2. #2 Re: Crankcase vacuum?
    did you replace the PCV valve while you were doing maintenance?
  3. #3 Re: Crankcase vacuum?
    The PCV has two o-rings. One on the valve below it and one on the cap above the valve. If either ring is missing...you'll have issues.
  4. #4 Re: Crankcase vacuum?
    Twin Falls, Idaho
    Ok, this may sound dumb...
    I can not find a pcv valve on that thing. Where SHOULD it be? The new (& old plenum) plenum doesn't have one, it's not on either valve cover, & there's none on the lower intake manifold.
    Am I just being an idiot? It does happen from time to time!
    Thanks,
    Greg.
  5. #5 Re: Crankcase vacuum?
    its part of the upper intake manifold. its on the passenger side. you have to twist a cap off and its underneath there.
  6. #6 Re: Crankcase vacuum?
    Twin Falls, Idaho
    Damn, I feel like a moron. About 10 minutes after I asked where is it, I was going back to work & remembered it's under the pressure sensor on the left of the upper plenum.
    Thanks, guys, for helping jog my memory!
    Greg.
  1. crankcase ventilation valve?
    By jmanners in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-10-2009, 08:54 PM
  2. Vacuum line
    By drewz313 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2009, 02:11 PM
  3. vacuum
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 10-05-2009, 09:09 PM
  4. vacuum pressure
    By grand2000prixgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-10-2009, 12:14 AM
  5. Vacuum hose
    By Onthebrinc in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-12-2008, 07:01 AM
