Thread: Exhaust Work?
Results 1 to 20 of 33
  1. #1 Exhaust Work?
    Donating Users Taz Magister's Avatar
    Dec 2010
    Ohio
    Alright so Ive decided that the next direction I want to go with modding my car is exhaust and some suspension stuff because Ive come to realize that yeah you can make this thing fast but its just to expensive to get real results so I want to make it sond good, drive good, and look good, but I have no Idea what to do for the exhaust I have the front part figured out though already have a zzp downpipe and about to get a power log, ported rear manifold, and cross over pipe all ceramic coated excluding the downpipe of course any ideas what I should do for the rest?
  2. #2 Re: Exhaust Work?
    Florida
    my setup will/is pretty similar.I dont have downpipe or plog yet but real soon.Id say glasspack or aftermarket resonator then some nice mufflers.After that your car should sound a lot better.
  3. #3 Re: Exhaust Work?
    Feb 2008
    Honestly.. I would just get headers. It would be cheaper and probably much better. I was thinking about getting a plog, but that is only because I'm too lazy to pull off the rear mani. If you are willing to do that you for sure should get headers. As I said, they will be Cheaper!
    As for exhaust.. I'd keep it really mild. Do some research on some good mufflers, replace the stock res with a glasspack and call it a day. These engines sound like crap.
  4. #4 Re: Exhaust Work?
    Dec 2010
    Ohio
    the reason Im going with power log and what not is because I already have a downpipe on the car plus no loss in low end torqe im thinking i might just bite the bullet and get a borlla system for the back idk
  5. #5 Re: Exhaust Work?
    Florida
    Do you notice better soundand performance with the downpipe? and what would you reccommend to remove the upper bolts on the downpipe?
  6. #6 Re: Exhaust Work?
    Donating Users NoBoost91's Avatar
    Queens, New York
    Quote Originally Posted by dmahlikGT View Post
    exhaust definitely got louder and i do notice a little extra pull on the top end, as for those bolts i used a half inch ratchet with a few extensions
  7. #7 Re: Exhaust Work?
    Florida
    ok i see.Nice.I plan on getting my downpipe within a month
  8. #8 Re: Exhaust Work?
    Minnesota
    Quote Originally Posted by Taz Magester View Post
    Drop to a 3.4 pulley and youll get that low end torque back
    Open cone, SSAC headers, cat delete, 8.5 MSD wires, 3.4 zzp mps, 180*, 104's, ported blower, DHP canned tune, 19" XXR 962s, DNA springs.
  9. #9 Re: Exhaust Work?
    Quote Originally Posted by Ricky21 View Post
    we're in naturally aspirated land?
  10. #10 Re: Exhaust Work?
    brentwood
    is a resonator the same thing as a glass pack. cause magnaflow has resonators. and glass packs .can thay replase the mufflers. what would sound better.
  11. #11 Re: Exhaust Work?
    true test of how a motor sounds is running it with open headers......
    and this engine fails that test miserably.
  12. #12 Re: Exhaust Work?
    put a glass pack (biggest one you can fit) in place of the resonator then look for a "turbo" style muffler.
    By turbo style muffler i mean something that is based on a stock design yet more "performance" orientated.
  13. #13 Re: Exhaust Work?
    GT Level Member Dtrick22's Avatar
    Jul 2010
    Holyoke, MA
    Agreed....That's my setup and I like it....I wasn't throwing big money into an exhaust, I would rather put the money where it counts (motor) so I went the cheap route with Thrush glasspack ($20) and Thrush Turbo mufflers ($30 a piece)
    2006 GT- S1x, 3.25 MPS, Lucas 42.5, MAF, SD Headers, C5 Brakes, AGX/Vogtland, GMPP sways
    Quote Originally Posted by Wotgtp View Post
    I eat, drink, sleep, and masterbate to grand prix's. Come at me bro.
  14. #14 Re: Exhaust Work?
    The LED guy.... csssaint12's Avatar
    Nov 2009
    Duluth, Minnesota, United States
    Only bad thing that I found is that when I got a new muffler on my car that the drone increased greatly but has a nice deep rumble. Just something to keep in mind.
  15. #15 Re: Exhaust Work?
    SE Level Member GMGUY's Avatar
    Dec 2010
    West Jordan Utah
    I just completed my system, took off the res and went with flomasters...als0 changed the pipe to 2.5 stainless... sounds great at idle and take off and when passing but nice sound at cruzing speeds...I hate the harmonics of some systems at 2200 rpms..
  16. #16 Re: Exhaust Work?
    Quote Originally Posted by GMGUY View Post
    you have a gxp, you dont count.
  17. #17 Re: Exhaust Work?
    Agreed, big difference from 5.3 liters and 8 cylinders vs. 3.8 liters and 6 cylinders.
  18. #18 Re: Exhaust Work?
    larger diameter and longer resonator would help with that.
  19. #19 Re: Exhaust Work?
    Nov 2009
    Don't mind the drone that much too do that because one of these summers going to be doing some custom exhaust work on my car.
  20. #20 Re: Exhaust Work?
    Exhaust work should be headers, deleting the converter...and some sort of a resonator. That's it.
  1. Is it safe to drive with an Header exhaust leak or any exhaust leak??
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 05:45 PM
  2. New exhaust work: now my performance SUCKS!!!!
    By Billy Low in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-28-2009, 01:55 PM
  3. 07 Exhaust work
    By llAkUmAll in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-23-2009, 06:18 PM
  4. exhaust work
    By mrbiggun1994 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-11-2008, 01:18 AM
