Hello,
I was out today and stopped at a corner store, and when I came back out to start my car it would not start. It turned over no problem. The oil, temp, battery, and engine light were on. I tried again to start it and nothing. After 15 minutes I tried it again and it was slow but it turned over. SO I made it home ok. tried to start it after shutting it off and it started ok. I tested the battery and alternator with a load test and it was fine in the voltage. I am not a mechanic, but reading up on you tube helped in testing out the two main things that would give me problem. The battery is new from this past christmas. At one point at the corner store, just the battery light was coming on, yet the car was still turning over. So I am not sure where to go next?? I mean to bring it in the garage and if it is not doing this, I am wasting money if they don't catch it. I have an Can OBD2 scanner and it came up with nothing.
So what do you suggest I do now???
Thanks
Joanne
