Thread: Fram oil filters - crap or not??
Page 13 of 13 FirstFirst ... 3111213
Results 241 to 245 of 245
  1. #241 Re: Fram oil filters - crap or not??
    SE Level Member jakechil101's Avatar
    Jul 2011
    indiana
    Quote Originally Posted by 40th GP View Post
    I thought the extra guard was their entry level filter. Is this filter off the shelf or a special filter they use only in the service bay? Does it have a name? Do you have any pictures?
    its a shop filter. you cannot buy it off the shelf. ill have to get a picture for you when i go to work on friday. its also called the fram cor tle filter
  2. #242 Re: Fram oil filters - crap or not??
    SE Level Member Sold Honda Bought Hondo's Avatar
    Apr 2011
    havazoo
    It's me again..lol
    And been running a fram.....no, not the el cheapo ph 4 racing....inside is nothing like the one that came apart. Ran the last one 52 hours with 50wt v-racing, mellings hv with 2 shims under the spring and plugged filter bypass. Makes 60 psi cold @1100 40 hot and 65 hot @ 6800 and 240* oil temp. I run motor hard it gets about 5 min part throttle warm up in summer and then gets hammered. And if it's not getting hammered it's idling for 1/2 hr at a time @ 1000 rpm with a .700 lift roller cam and 220/500 springs...
    Don't know how good it actually filters until i pull pan this winter although i have never run 52 hrs on oil/filter and the oil wasn't all that bad.....and that was 52 hours after replacing the block over a crack issue. Quick hone, fresh cam bearings....used same rings/bearings gaskets...that be the 6th time i re-used the head gaskets....
    If i were to say anything about fram filters... They would do well if they ditched the entire line of budget filters, even an occasional failure like the one i had is not acceptable. At this point i will say the racing filter seems to be able to flow enough 50w oil to maintain pressure. (my deal runs very loose bearing clearances...with normal clearance it would make 90 psi pressure...so i need the filter to flow more oil than most motors)
    Besides.....premium oil filters are hard to get in this town and the ones that are available have an internal bypass....and if i wanted the oil to bypass the filter i wouldn't have plugged the bypass in the first place.Bypass is fine and dandy for a basic transportation car that doesn't generate a lot of material from wear...and they are fine in cold weather...If mine generates metal from something as simple as honing cylinders the freshen it up that material ends up in the bottom of the pan...and it's the first oil that gets pumped through the motor after sitting for a week or 2. The thought of that oil going straight to the bearings because of a bypass seems stupid.
  3. #243 Re: Fram oil filters - crap or not??
    A worthy post.
  4. #244 Re: Fram oil filters - crap or not??
    Apr 2011
    havazoo
    Quote Originally Posted by motorking View Post
    If you ever experienced a failure due to a defective oil filter, we would be buying you an engine period.
    Damn Fram filter....been trying for a new motor but i can't get the filter to cause a problem.lol
    Bbc Gen 4 oiling - Page 5
  5. #245 Re: Fram oil filters - crap or not??
    GTP Level Member
    Aug 2012
    st louis park, MN
    Quote Originally Posted by jakobkay View Post
    My friend works at the orielies warehouse he said the frams suck Wix is the way to go
    Based on the fact that he works in the warehouse?
    Really? WIX filters are 85% efficiency, the lowest cost ORY filter (made by Fram) is 92%, lowest cost Fram filter is 95%. Guess it's just a matter of how much dirt your willing to let through your engine.
    Letting dirt in your engine?! That doesn't sound good at all!
  1. K&N filters bad?
    By Black18Ice in forum General Tech Discussion
    Last Post: 09-02-2009, 11:30 PM
  2. Oil filters
    By TheOtherNick in forum General Tech Discussion
    Last Post: 07-19-2009, 11:17 PM
  3. oil filters dissected
    By blowfishRus6 in forum General Tech Discussion
    Last Post: 07-14-2009, 10:20 AM
