Thread: New Rockers???
Results 1 to 11 of 11
  1. #1 New Rockers???
    GT Level Member duane9586's Avatar
    Apr 2008
    ny
    is it worth replacing the rockers and if so what size and what springs to go with them? 05 GP N/A 3800. Thanks in advance
    180*, Overkill, K&N, MSD, GEN V, AL 104's,ZZP Shift kit,SD Headers,1.9rr's, 90#,3.2zzp,0KR, 8K HID,Was a Base Model
  2. #2 Re: New Rockers???
    Barksdale AFB, LA
    ER rockers, 105# springs on the intake valves.
    2009 Subaru Impreza WRX STI
  3. #3 Re: New Rockers???
    Apr 2008
    ny
    what about exhaust?
  4. #4 Re: New Rockers???
    Apr 2008
    ny
    i am also adding the hv3 insert
  5. #5 Re: New Rockers???
    Barksdale AFB, LA
    Quote Originally Posted by duane9586 View Post
    what about exhaust?
    Stock springs are fine with ER rockers on exhaust valves.
  6. #6 Re: New Rockers???
    Apr 2008
    ny
    Quote Originally Posted by Sabrewings View Post
    is there any reason why i shouldnt use matching springs?
  7. #7 Re: New Rockers???
    Barksdale AFB, LA
    The fact you're buying double the springs for no reason? Plus double the work for install? Up to you I guess, but the intakes require 105#s when doing any higher revving.
  8. #8 Re: New Rockers???
    Apr 2008
    ny
    Thanks for all of your input and help. makes life a little easier.
  9. #9 Re: New Rockers???
    GT Level Member rodman's Avatar
    Apr 2008
    Whats the 105's coldplugs???
  10. #10 Re: New Rockers???
    Barksdale AFB, LA
    Quote Originally Posted by rodman View Post
    Posted earlier in the thread...
  11. #11 Re: New Rockers???
    St. Louis Mo.
    He was referring to the type of spring needed. Not a sparkplug.
    Autolites do have a 103 and 104 style plug, but that's for another post
    James Shafer
    St. Louis MO
  1. rockers
    By rodman in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-30-2008, 05:14 PM
  2. cam or rockers
    By GP2003GT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-19-2008, 04:04 PM
  3. Rockers and Supporting
    By silvermistGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-28-2008, 04:03 AM
  4. Roller Rockers
    By IndeedSS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-19-2008, 05:49 PM
