Thread: Low Engine Oil light
Results 1 to 10 of 10
  1. #1 Low Engine Oil light
    Michigan
    So my low oil light came on Friday afternoon (07 Base GP), turns out the car was 1.25 quarts low.
    Had the oil changed in Dec and I am using Valvoline Syn Power 5W 30. The DIC/Oil Life Monitor hasn't sounded the alert for an oil change, the oil isn't really dirty, and I had only gone 5200 miles(mostly in town).
    Is it normal for these cars to burn off 1.25 quarts in that amount of time/miles??
    Thanks
  2. #2 Re: Low Engine Oil light
    Pennsylvania
    Really, you shouldn't burn any oil. You can either shrug it off and remember to keep refilling your oil or track down the gremlins and get your car running perfect. Regardless, it's time for an oil change.
  3. #3 Re: Low Engine Oil light
    Michigan
    The oil has been changed now.
    The throttle body is a little dirty which I still need to hit with some cleaner.
    What else should I look for?
  4. #4 Re: Low Engine Oil light
    GTX Level Member Rather B Blown's Avatar
    Dec 2008
    London, Ontario
    look for oil leaking down the block..common places are out of the valve covers, LIM, heads, or oil pan
    Quote Originally Posted by Reptile
    It sounds like you accidentally stuffed a midget in the downpipe, and he's hammering out an SOS to get out.
  5. #5 Re: Low Engine Oil light
    SE Level Member nault31's Avatar
    Southside Chicago Suburbs
    Sounds like normal consumption to me, I lose about a quart after 6000 miles, though I drive that in 3 months not 8. My most recent popular mechanics states that even 1 quart after 1000 miles is considered normal consumption in some engines.
    ^^I realize a stock L36 is not as fast as the sticker implies, but this sticker has worked and it is still a hell of a lot of fun to drive considering it's a grocery sedan.
  6. #6 Re: Low Engine Oil light
    Dec 2008
    London, Ontario
    losing a quart of oil every 1000 miles isnt normal, i dont care what popular mechanics says
  7. #7 Re: Low Engine Oil light
    Michigan
    There is no visible oil on the engine...the bottom is dry, the valve covers, LIM etc are clean.
    The intake manifold is really dirty, fine coating of what appears to be oil...could the PCV system suck that much oil into the intake?
  8. #8 Re: Low Engine Oil light
    try something: start the car and pull off the oil cap on the front valve cover. put your hand over it, does it suck a bunch of air in? your PCV valve might be bad.
  9. #9 Re: Low Engine Oil light
    Donating Users Deezul_AwT's Avatar
    Feb 2008
    Cumming GA
    My GP triggers the low oil light, I put in about a quart, and about 200-300 miles later, change oil light comes on. I'm using synthetic, so I can go a few more miles, but I've just come to accept that a car with 130k miles burns oil. No visible leaks anywhere; I've parked it on the street and I never got any puddles. I just know to keep the oil from that last quart bottle in the trunk of my car and pour it in when the low oil light comes on.
    2016 Ford Fusion Energi Titanium - Still trying to figure out what I can do
    2006 Mercury Mariner Hybrid - K&N Drop in filter. Not much else you can do...
    TOTALED 9/2016 - 2004 Impala SS
    SOLD 3/2013 - 2000 Grand Prix GT
  10. #10 Re: Low Engine Oil light
    GTX Level Member bronzemist02's Avatar
    Canada
    My oil light is on too. Changing it today. Has less than 5000 kms on oil. It didn't come on with the last type of oil I used castrol I think.
    02 GT: Silverstar ultras, nighthawk platinum 2157s, ngk plugs, champion wires, 6k hid fogs, stainless magnaflows, cleaned tips, 2 10" subs. Finally painted.
  1. engine light
    By X97prixX in forum General Tech Discussion
    Last Post: 04-03-2010, 04:15 PM
  2. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
  3. engine light on and off
    By stanggreg90 in forum General Tech Discussion
    Last Post: 09-17-2009, 02:32 AM
  4. Engine Light
    By birdgm in forum General Tech Discussion
    Last Post: 05-09-2009, 09:12 PM
  5. Engine light came on what to do?
    By jasonball in forum General Tech Discussion
    Last Post: 12-03-2008, 03:44 PM
