Thread: Engine oil leak
Results 1 to 2 of 2
  1. #1 Engine oil leak
    SE Level Member grandprix85's Avatar
    Milwaukee, WI
    About a month ago my car was in the shop getting the intake gasket manifold replaced. They had gave me a oil change too in case some coolant got into the engine. About a week later I noticed that I was leaking engine oil so I took it back and they checked it out and they said I had a faulty oil filter or something like that. I dont remember what they had said but they said it shouldnt leak anymore. Last week I noticed its leaking again, but its not real bad. After letting my car sit about 8 hours at work, I'll notice 4 or 5 spots about 2-3 inches in diameter on the ground. It looks like it would drip about 1 or 2 drops every 20 mins or so. What do u think is the problem? I have a 2002 Grand Prix GT with 100,970 miles.
  2. #2 Re: Engine oil leak
    Outer Space
    Quote Originally Posted by grandprix85 View Post
    Check your oil drain plug. If its wet with oil.. wipe it off... then check it later that day. If it's wet again... you know where your leak is.
    02 GTP 13.6 @ 100mph - SOLD
  1. oil leak on 3.4 dohc. Not that oil leak.
    By 67GTO in forum General Tech Discussion
    Last Post: 06-14-2010, 11:52 AM
  2. vac leak i think?
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 05-26-2010, 07:55 AM
  3. Spartans Engine Swap (Engine Damage Pics on Front Page!)
    Last Post: 05-05-2010, 12:50 AM
  4. Engine overheats, heater blows cool air, leak by egr tube
    By twillroth in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-30-2009, 03:13 PM
