Thread: Thing in the Fuse box
Results 1 to 16 of 16
  1. #1 Thing in the Fuse box
    SE Level Member Skeeve's Avatar
    carneyville FL
    does anyone know what this thing is in the engine fuse box?
    99 Grand Prix GT
  2. #2 Re: Thing in the Fuse box
  3. #3 Re: Thing in the Fuse box
    carneyville FL
    based on the symbol on it, thats a diode.
    ok, so umm... the black plastic part on it has melted, something i should be concerned with? and damn that was a fast response!
    99 Grand Prix GT
  4. #4 Re: Thing in the Fuse box
    yes, if it was hot enough to melt then the diode is toast as well.
  5. #5 Re: Thing in the Fuse box
    Willoughby, Ohio
    the diode probably got so hot while it burned up it melted the plastic
  6. #6 Re: Thing in the Fuse box
    carneyville FL
    Does anyone have an idea of what it is for? It looks completely burned up and I was told today that my compressor isnt working, was hoping there was a connection between the two.
    99 Grand Prix GT
  7. #7 Re: Thing in the Fuse box
    does the fuse box lid not have a diagram?
  8. #8 Re: Thing in the Fuse box
    carneyville FL
    yes it does, but unfortunately it just shows a black block and thats it.
    Nevermind, found a pdf... its the ac clutch diode, my next question would be, if this is burned out would this cause the compressor to not work?
    99 Grand Prix GT
  9. #9 Re: Thing in the Fuse box
    Found this in the fm manuals
    The diode of the A/C compressor clutch connects across the terminals of the A/C compressor clutch. The diode provides a path for the current which results from voltage spikes. Voltage spikes generate from the collapsing magnetic field of the A/C compressor clutch coil. Voltage spikes occur every time the coil de-energizes.
  10. #10 Re: Thing in the Fuse box
    carneyville FL
    ok so in laymans terms? lol
    99 Grand Prix GT
  11. #11 Re: Thing in the Fuse box
    laymans terms: you need that diode in order to not fry your a/c compressor clutch.
  12. #12 Re: Thing in the Fuse box
    carneyville FL
    thank you, so now.... if the clutch still kicks on when i turn the ac on then it would be the compressor thats shot right? (i dont have a lot of trust for mech shops)
    99 Grand Prix GT
  13. #13 Re: Thing in the Fuse box
    Donating Users alkygto's Avatar
    Nov 2009
    wentzville
    Subscribing
    My A/C has'nt worked all summer, just went and checked my diode and no reading either direction , too bad my engine is toast so I can't see if I need to replace the compressor while the motor is out.
    1997 Pontiac Grand Prix GTP
    1969 Pontiac GTO
  14. #14 Re: Thing in the Fuse box
    carneyville FL
    wouldn't the engine need to be running for current to flow through tha diode?
    99 Grand Prix GT
  15. #15 Re: Thing in the Fuse box
    Nov 2009
    wentzville
    No, I took it out and checked for resistance through the diode with a meter, it showed 0 both ways ( current only flows one way through a diode). BTW mine is not melted.
    1969 Pontiac GTO
  16. #16 Re: Thing in the Fuse box
    Take a look at the schematic though guys. That diode is merely there to take the bumps out of the electrical system that may hurt the compressor. Technically the compressor should still operate w/o the diode in place.
  1. such thing as bad gas?
    By BoostedComp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-30-2009, 03:56 PM
  2. Am I doing the right thing?
    By SlowM90 in forum The Rant Forum
    Last Post: 04-24-2009, 07:26 PM
  3. How lame is this thing
    Last Post: 02-17-2009, 12:24 PM
  4. Freaky thing
    By SlowM90 in forum Off Topic Discussion
    Last Post: 12-12-2008, 09:10 PM
  5. Any thing going on near miami FL
    By KingOfTheSouth in forum Shows and Events
    Last Post: 11-03-2008, 06:17 PM
