Thread: speedometer problem
Results 1 to 3 of 3
  1. #1 speedometer problem
    SE Level Member chitownwhitestrip's Avatar
    Chitown
    I swapped out the engine in my 2002 go and now my speedometer isn't working n also my ABS light came on n hasn't turned off . Any ideas any suggestions ? Thanks appreciate any help I could get
  2. #2 Re: speedometer problem
    SE Level Member Wisconsingrandprix's Avatar
    Aug 2011
    roun here
    well the abs is prolly a bad wheel bearing
  3. #3 Re: speedometer problem
    Florida
    swapped from what engine to what engine? were they the same engine? did you change tranys? or PCM's? a few more details will help us help you.
  1. speedometer problem
    By gtpsupercharged in forum General Tech Discussion
    Last Post: 12-07-2009, 08:22 AM
  2. Slow Speedometer
    By DanGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-08-2009, 10:27 PM
  3. Speedometer ??
    By 04BlackComp_G in forum General Tech Discussion
    Last Post: 04-17-2009, 10:53 PM
  4. speedometer
    By digilue in forum General Tech Discussion
    Last Post: 12-28-2008, 07:10 AM
  5. Speedometer Problem
    By GTPOWER in forum General Tech Discussion
    Last Post: 07-23-2008, 12:33 AM
