Thread: oil spraying
Results 1 to 10 of 10
  1. #1 oil spraying
    Canada
    i have oil spraying out of what looks like the valve cover gaskets, it doesnt spray out on idle but when the rpms are over 1500 it sprays. what should i do?
    on a side note when i rev the engine the MPH goes up while in park or neutral, this started right after the car started spraying oil
  2. #2 Re: oil spraying
    it SPRAYS out? to do that you'd need a ton of crank case pressure, which isnt normal.
  3. #3 Re: oil spraying
    Check your PCV, it sounds like it's installed incorrectly. Hence you are building crankcase pressure.
  4. #4 Re: oil spraying
    Jun 2010
    Hampton, VA
    The PCV only goes in one way and if it were reversed, damaged or stuck open, the vacuum on the case would be huge. A blocked pcv will cause a pressure increase. remove the oil fill cap and check for pressure with the engine running.
  5. #5 Re: oil spraying
    New Jersey
    Do these cars have both a pcv valve as well as a vent like the older engines had? typically the vent was in one valve cover going to the air cleaner and the pcv valve was in the other.
    if so its impossible to build pressure even with a plugged pcv valve.
  6. #6 Re: oil spraying
  7. #7 Re: oil spraying
    New Jersey
    thats depressing...
    I feel like I lost something I never had
  8. #8 Re: oil spraying
    you do have a vent when you have to reroute your PCV system when you block it with an intercooler though...but that's something you'd make.
  9. #9 Re: oil spraying
    GTP Level Member Scimmia's Avatar
    QCA, IA
    We do have a vent, if you want to call it that. What you're talking about is the inlet side of the PCV system. It's a small hole in the throttle body, which gets routed through the blower and LIM into the front head. It's small, though, so you'll still build pressure with a blocked valve or vacuum with a stuck valve.
    2001 Buick Regal LS - Almost Stock
  10. #10 Re: oil spraying
    New Jersey
    Scimmia : thats exactly what i'm talking about. However on the older engines it was a 1/2" pipe or so.
