Thread: 2004 GT Top Swap (Lots of Pictures)
Results 1 to 20 of 77
Threaded View
  1. #1 2004 GT Top Swap (Lots of Pictures)
    Donating Users Storm's Avatar
    LaCrosse Wisconsin
    I am starting my top swap soon. I plan on running a 3.8" pulley. Nothing serious.
    Here is my parts list:
    -L67 lower intake manifold
    -L67 Heads
    -M90 Supercharger
    -L32 fuel injectors
    -L32 fuel rail
    -Idler Pullies
    -Bracket to mount coil pack
    -Harmonic Crank Balancer
    -Coolant Elbow
    -Valve Covers
    -Supercharger Belt
    -PCM retune
    -Valve Cover gaskets
    -Head bolts
    -Plenum Gasket for L67
    -Rocker Bolts
    -TB gasket
    -TB adapter
    -180* thermostat
    -Supercharger O-ring
    -1 step colder plugs
    -Head Gaskets
    Does that sounds like a 100% complete list?
    Also here are a couple of questions about the swap that I was just curious about?
    1. Will I need to modify the Gen III supercharger in any way?
    2. I have an electronic throttle body. Do I need the L67 TB or can I keep the one I have?
    3. What exactly is the harmonic crank balancer? Do I need this?
    4. I JUST replaced the LIM gasket with the new aluminum one, do I NEED a new LIM gasket set? Are they different on the L67?
    5. I heard some GTPs have 2 belts. With the setup I am going with will I just need a longer belt or will I have 2 separate belts?
    6. Will I need any wiring harness for the MAP sensor?
    7. Do I need to upgrade the fuel pump since I am using larger injectors?
    8. If I understand correctly the L67 uses a return style fuel system. Now I will have L67 injectors and rail, will I maintain a return-less fuel system?
    9. Someone mentions o-rings for the GEN III supercharger. What are these for and do I NEED them?
    10. Do i reuse my L26 exhaust manifolds? Basically do my L26 manifolds bolt up to the L67 heads?
    I really hope you guys don't think I haven't searched. I couldn't find the answers to these specific questions. If I am missing ANYTHING in my build please let me know. I would like this to go as smoothly as possible. I also am very willing to take pictures to help other out.
    Thanks for the help!
    FOR SALE
    TOP SWAP PARTS- PM ME
  1. 2004 series 3 3800 swap to 1998 series 2 car?
    By carpenterbronco in forum General Tech Discussion
    Last Post: 04-13-2010, 11:12 PM
  2. Top Swap on a 2004 GP-GT 3800 SIII
    By gpcustom in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-25-2009, 08:27 PM
  3. Engine Swap?? 2006 to 2004
    By gmangrandprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-28-2009, 09:13 AM
  4. 2004 lincoln Lsv8 or 2004 GP GTP?
    By Enjoijoe in forum General Tech Discussion
    Last Post: 03-10-2009, 03:58 PM
  5. Nav in 2004 GP1
    By Applebudds in forum Audio, Security & Visual Electronics
    Last Post: 02-04-2009, 12:17 AM
