Thread: 2004 GT Top Swap (Lots of Pictures)
Results 21 to 40 of 77
  1. #21 Re: 2004 GT Top Swap
    nope. you need the 2 bar map sensor and the pigtail for it.
  2. #22 Re: 2004 GT Top Swap
    GTP Level Member Scimmia's Avatar
    QCA, IA
    Quote Originally Posted by Storm View Post
    I don't think I will need a MAP sensor if I am correct. And please someone correct me if I am wrong. Doesn't the GenIII Supercharger come with a MAP sensor built in? I could just have to get an adapter to plug into the MAP sensor, right?
    No. First off, the Gen III doesn't have a MAP built in, it's mounted on a bracket on the back of the blower. Second, as I said, YOU HAVE TO MATCH THE MAP TO THE COMPUTER USED. If you're using your stock computer, you need to use your stock MAP.
    2001 Buick Regal LS - Almost Stock
  3. #23 Re: 2004 GT Top Swap
    Donating Users Storm's Avatar
    LaCrosse Wisconsin
    Quote Originally Posted by Scimmia View Post
    How the hell can I use the stock MAP if it doesn't read boost? ZZP says they will give me a tune for a top swap on my car, does this mean they will give me a PCM from a L32 engine?
    FOR SALE
    TOP SWAP PARTS- PM ME
  4. #24 Re: 2004 GT Top Swap
    ny
    I believe tuning it will fix that. If ZZP says they will give you a tune and you do not send in your pcm first than yes they will give you a new pcm.
    On another note, the harmonic balancer... This was the hardest part of the top swap for me. You have to remove the inspection cover and jam the flywheel with a HUGE screwdriver. Than either get an impact gun if available or a HUGE breaker bar. We had to use a breaker bar and the pole off of my jack to create an even bigger bar and the bolt broke loose easy. Than I had the pulley puller from advanced but the bolts were to big!!!! So either get one from ZZP or go to the hardware store by the longest skinniest bolts you have screw them into the pulley! Not behind the pulley like it is supposed to be used. (you might need to use sockets as spacers) Than twist the big bolt provided in your puller kit so that it pushes off of the crank. It is almost using the tool backwards. If you dont want to do this order the puller off ZZP and it can be used as it is intended.
    Also get a gen 5 supercharger and all the L32 components it will be much easier.
  5. #25 Re: 2004 GT Top Swap
    QCA, IA
    So what if it doesn't read boost? It'll go to 100 kPa and stop. Oh well.
    If you get one from ZZP, it's probably going to be an L32 tune, in which case you'd want to use a 2 bar MAP.
  6. #26 Re: 2004 GT Top Swap
    Uh vice grips on the flexplate would be easier.
    Just use a nice 1/2" 40" breaker bar and a 15/16'ths socket. Use the car as leverage and it should come off.
    I found it more difficult torquing it back down than getting it off.
    Just get the ZZP bolts and make sure they're fully threaded before you start trying to pull it off.
    Lets settle this once and for all... you NEED a 2 bar MAP sensor. Get one, and make sure the map tables are for the tune that sensor is from.
    Top swap IMPLIES you are using the GM 2 bar map sensor.
  7. #27 Re: 2004 GT Top Swap
    LaCrosse Wisconsin
    Damn this is going to be a hit on the pocketbook if I go Gen V instead of Gen III. I was hoping to get the whole thing done for around $700. Can I get the Gen III intake manifold and still use the Gen V blower?
    FOR SALE
  8. #28 Re: 2004 GT Top Swap
    LaCrosse Wisconsin
    Can anyone tell me what A and B are in this picture? A looks like a cap-off for something and B looks like what I thought the MAP was. Is this correct?
    FOR SALE
  9. #29 Re: 2004 GT Top Swap
    QCA, IA
    A is the cover for the PCV valve, B is just a vacuum manifold; it gives you three vac ports.
  10. #30 Re: 2004 GT Top Swap
    LaCrosse Wisconsin
    This is a picture of a Gen V supercharger it confirms that the L32 fuel rail and injectors will bolt in because that looks exactly like my L26 injector rail configuration except injectors bosses are in heads not intake manifold. Can someone point out the whereabouts of the MAP sensor on this engine.
    Thanks
    FOR SALE
  11. #31 Re: 2004 GT Top Swap
    LaCrosse Wisconsin
    Continuing with a couple questions here.
    1. What sensor is this?
    2. Where will this hook up to?
    3. Will need this tube after the swap?
    4. Where will this sensor be located? Is it going to be on the supercharger? What is this sensor called?
    5. To take the fuel rail apart I take that clip off obviously... do I need a special took to get the connection apart or do you "pinch" it and it comes apart?
    6. Do I need this coolant port from an L67 intake or are they interchangable?
    7. MAF sensor (obviously) I keep my stock MAF for the swap?
    FOR SALE
  12. #32 Re: 2004 GT Top Swap (Lots of Pictures)
    QCA, IA
    1. That's the EVAP purge solenoid. It's one I hadn't really considered. If you're using a Gen III, you'll need the L67 EVAP setup. The Gen V uses the same setup.
    2. That's the brake booster vac line, it goes to that vacuum manifold on top of the blower that we talked about earlier.
    3. That's another one I hadn't considered, it's the PCV inlet. You'll either need to get mini to add a port for that on the adapter or run the line to the front valve cover instead. Again, that's only if you use the Gen III, it should hook right up to the Gen V.
    4. That's the MAP sensor.
    5. You need a special tool, available at any auto parts store.
    6. They're the same.
    7. Keep your stock MAF.
  13. #33 Re: 2004 GT Top Swap (Lots of Pictures)
    LaCrosse Wisconsin
    So I am going to go with the Gen V blower. To do this can I jsut get the Gen V blower and the L32 lower intake manifold and get L67 heads? Bascially what I am asking is will the L32 intake manifold bolt up directly to the L67 heads or do I need to get L32 heads too?
    FOR SALE
  14. #34 Re: 2004 GT Top Swap (Lots of Pictures)
    QCA, IA
    The heads themselves are the same casting. No difference at all.
  15. #35 Re: 2004 GT Top Swap (Lots of Pictures)
    GTP Level Member
    Pittsburgh
    you dont need the L32 LIM. but if you really want one and if you cant find a L32 intake, then just cut and open the L67.
    2003 SSEi,
  16. #36 Re: 2004 GT Top Swap (Lots of Pictures)
    LaCrosse Wisconsin
    Speaking with another member on here who has done this same swap before except he did a Gen V on a 2005 GT, he said I am goingto have to wire in a barometric sensor to the PCM as well as wiring in the wires for the BBV. Easy to forget these things looking at the big picture. Doesn't sound too painful though. My parts list right now is looking like $1100 total for a Gen V swap. I think I could get a Gen III swap for closer to $800 or even $750.
    FOR SALE
  17. #37 Re: 2004 GT Top Swap (Lots of Pictures)
    First one is the MAP sensor... Second one doesnt need to be hooked up if you turn TCS everytime you get into the car.
  18. #38 Re: 2004 GT Top Swap (Lots of Pictures)
    LaCrosse Wisconsin
    What does your second sentence mean? Traction control system? So I don't need a barometric sensor because it only effects traction control system? very confused.
    FOR SALE
  19. #39 Re: 2004 GT Top Swap (Lots of Pictures)
    barometer measures pressure, thats what the MAP sensor does. MAP means Manifold Absolute Pressure.
    You dont need to hook up the BBV (Blow by valve) solenoid as long as you turn traction control off every single time you turn the car off. If you do not wish to disable traction control all the time, then you need to hook up the BBV solenoid.
  20. #40 Re: 2004 GT Top Swap (Lots of Pictures)
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    just get a full l32 top lim heads s/c map rail and injectors harmonic balancer and ideler pully reason i say l32 s/c is because it is more efficient and easier to put ur tb on to
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  1. 2004 series 3 3800 swap to 1998 series 2 car?
    By carpenterbronco in forum General Tech Discussion
    Last Post: 04-13-2010, 11:12 PM
  2. Top Swap on a 2004 GP-GT 3800 SIII
    By gpcustom in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-25-2009, 08:27 PM
  3. Engine Swap?? 2006 to 2004
    By gmangrandprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-28-2009, 09:13 AM
  4. 2004 lincoln Lsv8 or 2004 GP GTP?
    By Enjoijoe in forum General Tech Discussion
    Last Post: 03-10-2009, 03:58 PM
  5. Nav in 2004 GP1
    By Applebudds in forum Audio, Security & Visual Electronics
    Last Post: 02-04-2009, 12:17 AM
