Thread: P1133 Engine not running smooth?????
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
  1. #21 Re: P1133 Engine not running smooth?????
    Hoffman/Schaumburg, IL
    Just so you know, My intake made that noise from day one, it has to do with the port design for the IAC, if you put in a different throttle body(like a N*) the sound is different or reduced but still there
  2. #22 Re: P1133 Engine not running smooth?????
    Apr 2008
    New Hampshire
    which throttle body is that 02blue??? possibly a link or price or pictures etc? Thanks for the input though thats the best answer i have heard all afternoon!!!!
  3. #23 Re: P1133 Engine not running smooth?????
    Barksdale AFB, LA
    Quote Originally Posted by Gearhed42 View Post
    N* = Northstar
    Look on any 3800 performance parts site. You'll find it.
    2009 Subaru Impreza WRX STI
  4. #24 Re: P1133 Engine not running smooth?????
    Apr 2008
    New Hampshire
    northstar as in the caddy northstar?
  5. #25 Re: P1133 Engine not running smooth?????
    Apr 2008
    New Hampshire
    I just looked around ZZP and found the northstar TB which they only recommend for supercharged applications. But they also had a smaller TB for less money that they recommend for the N/A 3800. I didnt know if anyone had anything to add to my discovery? Is one better than the other? Will the northstar work in a N/A motor etc?
  6. #26 Re: P1133 Engine not running smooth?????
    Barksdale AFB, LA
    It's probably too big to be of use on the L36. Just get a stage 1 HVTB and call it a day.
  7. #27 Re: P1133 Engine not running smooth?????
    Apr 2008
    New Hampshire
    Awesome! Thanks sabre you basically rock!
  8. #28 Re: P1133 Engine not running smooth?????
    Apr 2008
    New Hampshire
    Do you think the hvtb will help cut down on some of the noise? I have heard that the n* tb helps cut down noise but havent heard positive or negative feedback on the zzp hvtb???
  1. Who is running ARP head studs???
    By Trannyman95 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-18-2008, 03:29 AM
  2. Rough when cold; smooth when warm...???
    By DanGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-11-2008, 07:34 PM
  3. Engine running too cold?
    By Deezul_AwT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-02-2008, 07:41 PM
  4. Running speaker wire....to the doors....help.
    By Incomudrox in forum Audio, Security & Visual Electronics
    Last Post: 02-21-2008, 02:14 PM
  5. Idler Pulley / 3" Smooth (8-Rib)
    By sra_chipmunk in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-05-2008, 12:34 PM
