Thread: Top Swapping I have questions.
Page 1 of 6 123 ... LastLast
Results 1 to 20 of 110
  1. #1 Top Swapping I have questions.
    Kansas
    In the near future i plan to top swap. I don't have many questions since Kfish has been answering damn near everything I can think of to ask.
    This is what I have:
    Heads
    Supercharger
    Throttle Body
    Valve Covers
    Idler Pulley
    Harmonic Balancer Pulley
    Fuel Rail w/ injectors
    Coil Bracket
    LIM
    This is what I need and here are my questions:
    Pulley belt - I prefer a 3.8 to start but do you guys think with everything I'm going to put on a can go smaller and if so how low?
    Headers - I'm probably going with speed daddy headers, I already know i need the different clamp. My questions are do those come with gaskets? If not where do I get the gaskets for them for the best price?
    Gaskets and Head Bolts - Is there a place where I can get all the gaskets in one set or do I have to buy them all separate and whats the best place to order them or pick them up? I was told that head gaskets come with head blots is this true?
    Tune - I think i'm set with this no questions here.
    Gauges - I'm going with a Aeroforce, oil pressure, and boost. Anyone think I should get a different combo? opinions are welcome.
    If im missing something please tell me. Anyone and everyone step in and help me out please
    SOLD 1999 GT Silvermist TS
  2. #2 Re: Top Swapping I have questions.
    Donating Users kfish's Avatar
    Ohio
    head gaskets do not come with the head bolts. head bolts come seperate.
    i would run a 3.8 on that set up, and run some decent timing. i dropped to a 3.5 right away on my car with only headers and was never able to get it 100% knock free.
    as far as gaskets for the headers go...they do come with them. but they are so cheap they fall apart just touching them. i would run the metal exhaust gaskets that your car has on it now. you should be able to re use them.
  3. #3 Re: Top Swapping I have questions.
    Kansas
    Any idea where to pick up a set of gaskets for everything else i need?
  4. #4 Re: Top Swapping I have questions.
    Quote Originally Posted by Gafford44 View Post
    Pulley - I prefer a 3.8 to start but do you guys think with everything I'm going to put on a can go smaller and if so how low?
    if i were you id start with the 3.8 just to get the car running well first, then start the pulley game.
    either get GM or felpro gaskets. even if they come with gaskets they are junk.
    get felpro or GM gaskets again and invest in some head studs. youll thank me later
    wideband? the only way to know how your car is ACTUALLY running as far as fueling goes.
    see above. done.
  5. #5 Re: Top Swapping I have questions.
    Ohio
    parts store or dealer like nick said. i used all felpro gaskets on my car.
  6. #6 Re: Top Swapping I have questions.
  7. #7 Re: Top Swapping I have questions.
    Ohio
    2 head gaskets
    Intake gasket set
    Plenum gasket set (if you ask for a supercharger gasket they look at you funny)
    TB gasket
    Fuel injector o rings (you need 2 boxes)
    Head bolts
    Coolant elbows (tell them your working on a GM 3.8. they'll know exactly what you mean)
    think thats it.
  8. #8 Re: Top Swapping I have questions.
    Kansas
    my man coming through again lol. Thats why i mentioned you in the first line of this thread
  9. #9 Re: Top Swapping I have questions.
    Ohio
    that stuff usually ran me about 200 bucks. but i also get my 20% employee discount
  10. #10 Re: Top Swapping I have questions.
    Kansas
    lucky bastard I'll try to get discounts lol
  11. #11 Re: Top Swapping I have questions.
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    i think u also need a gtp map sensor and if u put rockers on 3.5 should be ok
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  12. #12 Re: Top Swapping I have questions.
    Kansas
    Yea fish is going to hook me up with a MAP pigtail
  13. #13 Re: Top Swapping I have questions.
    Quote Originally Posted by nascartech View Post
    Not if you don't have headers and a custom tune. I really hope your not gonna be one of those guys that think you can just drop pulleys like you can on a L67 car...because you sure as hell can't on a high compression motor.
  14. #14 Re: Top Swapping I have questions.
    Hell, im running 14* of timing with pace****ter headers and get some knock here and there....
  15. #15 Re: Top Swapping I have questions.
    Kansas
    Im not even dropping the pulley after i top swap for a while. I just want to enjoy my newly top swapped engine for a while
  16. #16 Re: Top Swapping I have questions.
    But you'll want to soon enough.
  17. #17 Re: Top Swapping I have questions.
    Jersey
    i hit 13* of knock on a 3.6 and 14* of wot timing
    my setup- headers/1.9/N*
    stick with the stock pulley and start with stock gtp bin and go from there. Definitly get a wideband and a tuner or you will be wasting alot of your time trying to tune your car n/b and still not get anywhere. I recommend a dhp
    16' wrx sti- stock
  18. #18 Re: Top Swapping I have questions.
    Donating Users Storm's Avatar
    LaCrosse Wisconsin
    Sorry to threadjack, but any idea roughly how much a top swap would cost?
    FOR SALE
    TOP SWAP PARTS- PM ME
  19. #19 Re: Top Swapping I have questions.
    Jul 2008
    sumter,south carolina
    Quote Originally Posted by Storm View Post
    really depends on where u get parts from... id say 600-1000 to be done right.
    02 GTP with mods 05 GP for DD
  20. #20 Re: Top Swapping I have questions.
    Kansas
    Quote Originally Posted by 99prixgt View Post
    Im going to have brian tune my **** and I'm pretty sure he knows what he is doing. Going to go get gaskets and a Wideband today then order my headers and aeroforce.
  1. Swapping '03 radio for '04-'08
    By rpenling in forum Audio, Security & Visual Electronics
    Last Post: 03-21-2010, 10:28 PM
  2. Questions on swapping parts
    By mscally07 in forum Audio, Security & Visual Electronics
    Last Post: 08-07-2009, 12:59 AM
  3. Swapping engines
    By dbz09 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-06-2009, 12:51 PM
  4. Swapping PCM's
    By Clar2478 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-08-2009, 09:34 PM
  5. Swapping Engine
    By Redgtp1999 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-08-2008, 08:06 PM
