Thread: ECT sensor location?
Results 1 to 4 of 4
  1. #1 ECT sensor location?
    SE Level Member il0vellamas's Avatar
    maryland
    I have a 2001 GT, 3800 and need to replace the ECT sensor, or at least the code it's throwing says so. But I cannot find it! The Haynes manual is no help, and I don't see it anywhere! I know they are easy to replace if I can get to it, but where is it? Help!
  2. #2 Re: ECT sensor location?
    GTP Level Member Scimmia's Avatar
    QCA, IA
    It's right under the thermostat housing.
    2001 Buick Regal LS - Almost Stock
  3. #3 Re: ECT sensor location?
    maryland
    Wow, thanks! I found it right away! So now that I found it, I can't get it out. Do I need some special tool to get it out, it's in such a tight spot.
  4. #4 Re: ECT sensor location?
    maryland
    Got it. Finally. It was in such a tight spot. Thanks!
  1. ECT sensor location on 02 Grand Prix
    By seanpwhite in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-28-2010, 12:08 PM
  2. vss location
    By VJ Escamilla in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-02-2009, 04:34 PM
  3. Location of ECM
    By TOMB in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-17-2009, 01:26 AM
  4. IAT sensor location turbo?
    By UR LOSN in forum Turbo
    Last Post: 02-20-2009, 12:38 PM
  5. GTP PCM location
    By razoredge in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-16-2008, 07:36 PM
