Thread: should i get this??
Results 1 to 20 of 20
  1. #1 should i get this??
    Arizona
    '00 GT- nothing special
  2. #2 Re: should i get this??
    Florida
    I wouldnt, I'd just spend the money on a 9"cone filter, and some piping from the hardware store, and get much better flow out of it than that tiny cone.
  3. #3 Re: should i get this??
    Wichita
    Never heard of the filter brand before.
  4. #4 Re: should i get this??
    Florida
    Yeah, for the price, you could easily get a 9" Spectre or K&N filter, a hose clamp, and a little bit of pipe, and get way better flow out of it.
    Plus they sound really cool on the GT's, it's all you can hear when you step on the gas.
  5. #5 Re: should i get this??
    Arizona
    i saw a intake piping on zzp, would that do with a filter?
  6. #6 Re: should i get this??
    Florida
    Yeah, you can get that, with the ring and clamps, and get a filter at the local auto store, and be all set.
  7. #7 Re: should i get this??
    Arizona
    what option should i do
    add 4" hose clamp
    or add alluminum ring and 2 clamp?
  8. #8 Re: should i get this??
    Arizona
    k thanks
  9. #9 Re: should i get this??
    Florida
    Do the aluminum ring and 2 clamps, and you'll be all set.
  10. #10 Re: should i get this??
    If your asking those questions I think you need to rethink modding.
  11. #11 Re: should i get this??
    Arizona
    what do you mean
  12. #12 Re: should i get this??
    Quote Originally Posted by coreygnar View Post
    what do you mean
    he means, thats a crappy intake for a crappy price. if you get a crappy intake it should be cheap as hell.
  13. #13 Re: should i get this??
    Arizona
    i know that, i knew the filter would suck i was wondering about the tubing more so. then i saw the zzp tubing for much cheaper and asked if that would be good
  14. #14 Re: should i get this??
    SE Level Member Lionel's Avatar
    Moncton N.B.
    You could always get that and then buy a better filter, if you want a cleaner look than a homemade one. that's what i did with my saturn.
    since were on the topic. I currently have an AEM dryflow synthetic filter...
    3" inlet x 5" long
    all the intakes ive seen for our cars on here in pics have longer cones, is mine too restrictive?
  15. #15 Re: should i get this??
    Arizona
    Quote Originally Posted by Lionel View Post
    3" inlet x 5" long
    everyone says 3" is restrictive, 4" is better
  16. #16 Re: should i get this??
    SE Level Member eddie97gt's Avatar
    Feb 2009
    roanoke va
    i got ther fender mounted cold air on mine think i got it at w body store , works pretty good except the filter wouldent fit in the fender , got one of the short apc filters at advance work like a champ
  17. #17 Re: should i get this??
    Bigger the piping the better the flow in theory...unless your an idiot and put diesel exhaust pipe for an intake. 4" is what you should go with...then get a 3.5"-4" coupler for the TB. Buy a spectre filter from autozone...not $40 like the AEM dryflow and flows more air because of the design.
  18. #18 Re: should i get this??
    Willoughby, Ohio
    the tb seems more than 3.5 but i didnt measure.. a 4" coupler will work too just fyi
