Thread: Cold air intake question
Results 1 to 4 of 4
  1. #1 Cold air intake question
    illinois
    what cold air intakes will give me the most horse power without costing me a fortune?
  2. #2 Re: Cold air intake question
    build your own. Please you the search bar at the top. You will find your answer there.
  3. #3 Re: Cold air intake question
    illinois
    thanks
  4. #4 Re: Cold air intake question
    SE Level Member Lionel's Avatar
    Moncton N.B.
    I built my own yesterday and I'm no expert, first things first buy a cone filter, mine is 3", replace the the rippled rubber hose that comes out of TB as it is restrictive to air flow. replace it with a straight pipe at your local hardware store. you'll need to drill into it and install a grommet so you can reinstall the hose that goes into the engine.
    I used an air intake off my saturn 92 Sl2 (30$ ebay) and cut the pipe so it would fit and attached it to the end of the stock pipe that has a sensor attached to it.
    I saved over 300$ cuz i was thinking of buying a k & N intake.... and it sounds wicked!
    I'd post a pic but theres still a few things i need to tweak on my setup.
  1. Help with Cold Air Intake
    By Biohazardvi in forum Introductions/Noob Questions
    Last Post: 02-02-2010, 08:30 PM
  2. Cold Air Intake question
    By Kenny75k in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-17-2009, 05:26 PM
  3. cold air intake?
    By hodge in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-31-2009, 03:48 PM
  4. Help-cold Air Intake
    By sUpErClEaNbLaCkMaChInE in forum General Tech Discussion
    Last Post: 01-29-2009, 12:36 AM
