Thread: rockers
Results 1 to 6 of 6
  1. #1 rockers
    GT Level Member rodman's Avatar
    Apr 2008
    Looking to buy rockers for my n/a 06 with a few light mods 2.5 dp,
    power log, overkill pcm ,k@n cai,hv3 insert, jet mass airflow, res deleate
    Rockers 1.75 or split ratio
    Which set do you pros recomend
  2. #2 Re: rockers
    Barksdale AFB, LA
    ERs to make use of the better top end the HV3 will give you.
    2009 Subaru Impreza WRX STI
  3. #3 Re: rockers
    GT Level Member GP2003GT's Avatar
    Fayetteville, NY
    im about to have the HV3 HVTB and the ERs put in this spring...cant wait!
    http://www.cardomain.com/ride/2556536 NKG Iridium Plugs, 8mm Spiro Wires, ZZP Reprogrammed PCM, ZZP 3" full cat, ZZP Ceramic Coated Ported Manifolds, ZZP HV3, ZZP HVTB, ZZP ER Ratio Rocker Arms, ZZP Drilled 180* Thermostat, MotorSports Performance Intake, Reptile's IAT and dezldave tuned
  4. #4 Re: rockers
    GT Level Member mainecrab's Avatar
    Feb 2008
    How hard is it to put in rockers btw? I tried to find instructions that are sent out with them to give me and idea but couldn't find any.
  5. #5 Re: rockers
    Erie, PA
    mainecrab: instructions.... ClubGP:
    99 GP GT coupe on Chrome 18's with a K&N air intake
    R.I.P. Firefighter Michael D. Crotty whom anwsered his last alarm on April 8, 2008
  6. #6 Re: rockers
    Feb 2008
    Thanks, looks like its not terribly hard to do
  1. cam or rockers
    By GP2003GT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-19-2008, 04:04 PM
  2. roller rockers ?
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-23-2008, 12:28 PM
  3. Roller Rockers
    By IndeedSS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-19-2008, 05:49 PM
