Thread: Oil in Intake
Results 1 to 20 of 20
  1. #1 Oil in Intake
    Donating Users Storm's Avatar
    LaCrosse Wisconsin
    I took off my airbox and when I took the rubber boot off the throttle body, their was oil in there. Is this normal? There wasn't ALOT but enough to puddle in the rubber grooves.
    Thanks
    -noob
  2. #2 Re: Oil in Intake
    HUDSON
    no, that is not normal.
  3. #3 Re: Oil in Intake
    Grocery Getter x2 goldgp's Avatar
    redneck tennessee
    Mine had a little stain in the bottom of the tb when i got it,looked like oil was there b4 but its never done it since i had it.
  4. #4 Re: Oil in Intake
    Donating Users Warbeaver's Avatar
    St. Louis
    what kind of filter were you using?
  5. #5 Re: Oil in Intake
    LaCrosse Wisconsin
    K&N drop in. it was just in the rubber boot and there was only a small amount where the plastic breather from the upper plenium connects to the rubber boot.
  6. #6 Re: Oil in Intake
    New Jersey
    If the engine has high mileage and this is near where the crankcase vent is this is a common thing. Its caused by the engine having more blowby then the PCV valve can handle. My chev 350 was doing it a fair amount at 226K. If the engine has 150+K miles on it I wouldn't be surprised or concerned.
    At least it was on older engines
  7. #7 Re: Oil in Intake
    St. Louis
    have you re-oiled your K&N filter yourself ever? what color is this oil? and are saying the oil is in the rubber piping going from the throttle body to the air box?
  8. #8 Re: Oil in Intake
    LaCrosse Wisconsin
    Quote Originally Posted by Warbeaver View Post
    yes the oil is where you described it. It is engine oil,I know for a fact. its puddled in the little bellys of the rubber piping. right below where that plastic tube that runs from the upper plenium to the rubber pipe goes.
  9. #9 Re: Oil in Intake
    GT Level Member GeosGP's Avatar
    Fenton, MI
    MrTube has the right idea. It's blow-by from the PCV.
    2004 Grand Prix GTP Comp-G
    Stock, featuring more KR than you can shake a stick at
  10. #10 Re: Oil in Intake
    St. Louis
    how is it getting enough force to go back out the throttle body, through the screen against the incoming air from the intake?
  11. #11 Re: Oil in Intake
    Fenton, MI
    The PCV vent is between the MAF and TB I believe. That whole area is subject to vacuum at idle, so it pulls on the PCV system. If your PCV valve is crapped up, it won't seal properly and you end up with oil in the intake tract.
  12. #12 Re: Oil in Intake
    LaCrosse Wisconsin
    This wouldnt suprise me on a 200k mile engine, but i have only 65k miles. New upper and lower (aluminum) intake manifold gaskets from ZZP go in on Saturday along with valve cover gaskets.
  13. #13 Re: Oil in Intake
    doesnt mean the PCV cant be bad. its like a $3 part, go buy a new one and replace it.
  14. #14 Re: Oil in Intake
    New Jersey
    didn't it used to be typical to replace pcv valves every 20K or so?
    Btw, where is it located on the 3800 III? I haven't looked but itd be nice to know when I go to change it.
  15. #15 Re: Oil in Intake
    Fenton, MI
    I used to pull them out and shoot some carb cleaner through them. If they still stuck, they'd get replaced.
  16. #16 Re: Oil in Intake
    New Jersey
    Before I traded the truck in on the GP I had the pcv get gummed up and stuck, It used over a quart in 1000 miles.. with a good valve it did a quart in 2K, mind you the engine had 200-226K miles on it during this.
    Point being, the stuck valve caused it to slerp oil up big time. Tho with a proper working valve it ended up getting oil through the other vent due to blowby. By nowheres near as much.
  17. #17 Re: Oil in Intake
    Donating Users
    South Deerfield, MA
    To find the PCV, go to the passenger side of the black plastic upper intake manifold and remove a small cover. It is underneath that cover inside the manifold. Iirc, it is a twist off cap.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  18. #18 Re: Oil in Intake
    LaCrosse Wisconsin
    Quote Originally Posted by Silver GTP View Post
    I have the l26, aluminum plenium.
    FOR SALE
    TOP SWAP PARTS- PM ME
  19. #19 Re: Oil in Intake
    New Jersey
    Yea. I also asked about the series III valve...
  20. #20 Re: Oil in Intake
  1. Look at this intake on this cav
    By kjclawson in forum Off Topic Discussion
    Last Post: 01-07-2010, 08:49 AM
  2. 4'' intake on an 04?
    By gpgt04 in forum 04+ Specifics
    Last Post: 11-14-2009, 04:15 PM
  3. Coolant Loss, intake Gasket or Intake Itself???
    By WoR in forum General Tech Discussion
    Last Post: 04-29-2009, 04:02 PM
  4. intake
    By DDPeppa in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2009, 11:11 PM
  5. CAI air box w/ KN Intake???
    By zofsharick@gmail.com in forum Engine
    Last Post: 03-30-2009, 08:14 PM
