Thread: New gt prix owner
Results 1 to 20 of 28
  1. #1 New gt prix owner
    SE Level Member prixgt01's Avatar
    Schaumburg,il
    about to buy buy a 01 gt 3.8 with 99k on the clock. question i have for you is what to look for when buying one, engine and tranny wise? Also it will be my dd so good gas mileage is needed but want some mods. what the typical mods people do and is the engine i have a l26 or l36? not sure what thaty means and what the hp rating? thanks for the help in advance.
  2. #2 Re: New gt prix owner
    GT Level Member Madness's Avatar
    Nov 2009
    A little late
    You will want to try and find out if the upper and lower intake manifold gaskets have been replaced. GM's dexcool has been know to destroy them and let coolant into the oil.
    Favorite Quote: You can't fix stupid!!
    http://www.youtube.com/watch?v=0gxKStPXyn8
  3. #3 Re: New gt prix owner
    Serena, IL
    You have an L36, and with all the mods, you will probably be making stock GTP numbers...i would suggest a top swap if you want to make a lot of power. Yeah, def check the LIM gaskets.
  4. #4 Re: New gt prix owner
    Schaumburg,il
    Great thanks for the fast response, do i swap out the resonator, with a straight through muffler? something with muscle sound not a ricer fart sound. magnaflow,flowmaster, slp loud mouth? And i know a cold air intake anything else to kepp good gas mileage youd suggest and what years can i interchange parts with, whats the gen for this grand prix? And a top swap involes what. thanks agian
  5. #5 Re: New gt prix owner
    HP for a GT is about 200 HP at the crank, so to the wheels its going to be a little less.
    Gas Mileage for a GT on the freeway, you should get about 30-33( maybe more) City- around 20 mpgs.
    For the air intake just go cheap and make your own or just go on ebay and look up AIR INTAKE FOR GRAND PRIX. It just a pipe with a filter and works great and you should get better milage with it.
    Heres a link: Air Intake Pontiac Grand Prix SE GT GTP 1998 1999 2000 : eBay Motors (item 350216994722 end time May-18-10 20:27:24 PDT)
    As for exhaust the stock catback is fine. Its just the u-bend that is restrictive. For mufflers it your choice, I dont have a preference.
  6. #6 Re: New gt prix owner
    Schaumburg,il
    Is there a fender mounted intake for this car, would better pullin cold air then engine heat right? and where is the u bend at exactly?And if you take resonator out with no muffler will it jack the emissions? So thats why i was wonderin what muffler to replace it with. And as stated above whats involed with a top end swap? and what type of numbers to expect or problems? thanks
  7. #7 Re: New gt prix owner
    Colder air will give you more power but can decrease gas mileage. Hot air will give you better mileage but a little less HP. I am not genius about the reason why its that way but its true. Maybe someone else can give you the exact reason why.
    The u-bend is right behind the cat i think. There will be a sensor sticking out the top of it.
    If you have no resonator the car will sound very raspy, which will sound like crap. If you want a little more sound replace it with a glasspack. And I wouldnt go the no mufflers route. Just put some flowmaster, magnaflow or something like that. Check out youtube and see what you think. But its not gunna sound that good on there, its better in person
    As for problems. The main are gaskets. Valve cover gaskets and LIM. Most of the time the valve covers are in good shape. The transmission can go out on these car sometimes, but with good care and fluid changes they will last a very long time.
  8. #8 Re: New gt prix owner
    Nov 2009
    A little late
    I checked out this e-bay item and noticed it appears the filter is open at both ends? What am I missing? How does this filter the air going in?
  9. #9 Re: New gt prix owner
    Quote Originally Posted by Madness View Post
    Its called a open cone filter. They work the best and it will filter the air just like a normal one.
    Looks like this.http://www.rpmoutlet.com/images/mtb990098.jpg
  10. #10 Re: New gt prix owner
    GTX Level Member Biohazed's Avatar
    Philadelphia, Pennsylvania, United States
    X3 definatly check the LIM gaskets!! and welcome
    *image too tall*
    BMR F + R Strut Bars - Falken Torque V 18's - JVC S900 - Kicker C10's - Spyder Projectors, Wizaird,
  11. #11 Re: New gt prix owner
    Schaumburg,il
    ok sweet thanks for all the replies. Now what about the top end swap that was stated above what does that involve? And also if you delete the u bend with a sensor on the top of it do you have to re drill a hole for that sensor not to throw the ecu off?
  12. #12 Re: New gt prix owner
    Grand Island, Nebraska
    why has no one pointed him to this yet?
    http://www.grandprixforums.net/f81/s...car-17482.html
    That will teach you a lot about your car, read it more than once.
    http://www.grandprixforums.net/f17/t...lots-7763.html
    That will also teach you a lot, it explains what a top swap is. But basically, its taking the supercharger off of a GTP and putting it on your motor, to make you go fast.
  13. #13 Re: New gt prix owner
    Schaumburg,il
    thanks jorow90 for for the great advise. Im proud to say im a new grand prix owner went and picked it up today. Question for anyone is what type of oil is best for the var, spark plus and wires? anything else you guys suggest for tune up wise that i should know? thanks agian
  14. #14 Re: New gt prix owner
    Kansas
    One thing that wasnt mentioned was pay attention the trans and figure out when or if it has ever been rebuilt or replaced.
    SOLD 1999 GT Silvermist TS
  15. #15 Re: New gt prix owner
    Donating User Odi's Avatar
    Chicago South Suburbs
    spark plugs - copper ones. 3800 love copper spark plugs like Autolite 606. as for the wires, the stockers are fine. replace them if you want to with the oem ones. oil - i use castrol in my car (not the high milage one) and im changing it every 3000-3500 miles. hit 145 000 and the car is a dream.
  16. #16 Re: New gt prix owner
    Troy OH
    here's my attempt at a physics lesson.
    imagine a certain mass of air. at a certain temperature, it would take up a certain volume. as temperature changes, so does volume. with a lower temp comes a lower volume; a higher temp means a greater volume.
    now think about the combustion chamber of the motor. as the piston reaches the bottom of its cycle, the combustion chamber is at it's maximum volume (for this example, we'll ignore any knock retard effects). the way to get the most force from the eventual explosion is to have the most gas in the chamber, and since colder air takes up a smaller volume per unit mass, you maximize the amount of air/fuel mix in the chamber using colder air.
    since warmer air takes up a larger volume, the chamber fills up quicker with less air/fuel mix, meaning you get to save a little bit of gas. but since there is less fuel, you have less force from the explosion, therefore less power.
    in the real world, the temp difference between a fenderwell intake and a short ram or open cone intake isn't really that great. and because KR exists and limits the amount of gas you can compress before it combusts and shatters your piston, the two aren't much different. you can really just adjust timing to counteract the slightly higher intake temps from an open cone. as long as you can get sufficient air to the motor, you're good.
  17. #17 Re: New gt prix owner
    That was pretty well said.
  18. #18 Re: New gt prix owner
    Schaumburg,il
    thanks for all the replies they all will be well used and stored in the memory bank
  19. #19 Re: New gt prix owner
    I switched to synthetic oil after about 95K miles and havent had any problems yet, but im still on the first batch. I would go with the cheap lifetime warranty wires, the expensive ones only look cool, they wont give you any type of performance gain.
  20. #20 Re: New gt prix owner
    Schaumburg,il
    [QUOTE=JoRoW99;365100]I switched to synthetic oil after about 95K miles and havent had any problems yet, but im still on the first batch.< what weight are you using? and i just found and oil leak dripping down on the bottom of the block any ideas? Oil pan gasket, drain filter? thanks?
  1. New Grand Prix owner
    By trav07 in forum Introductions/Noob Questions
    Last Post: 02-08-2010, 03:10 PM
  2. New Grand Prix Owner here
    By shivley00 in forum Introductions/Noob Questions
    Last Post: 12-10-2008, 12:57 PM
  3. New Prix Owner here
    By NuwSkool04 in forum Introductions/Noob Questions
    Last Post: 12-10-2008, 12:50 PM
  4. New grand prix owner!!!
    By Z28 in forum Introductions/Noob Questions
    Last Post: 11-04-2008, 04:28 PM
  5. New Grand Prix Owner
    By xbnb1978x in forum Introductions/Noob Questions
    Last Post: 08-24-2008, 09:05 PM
