Thread: 2005 grand prix wont start
Results 1 to 9 of 9
  1. #1 2005 grand prix wont start
    Richmond,MO
    My grand prix ran fine the other day i went to start it this morning and all it does is crank im not getting any spark or fuel to the motor i checked all the fuses in both fuse boxes and they were fine there is also no trouble codes anybody have any ideas on what to check next?
  2. #2 Re: 2005 grand prix wont start
    Jul 2008
    Tampa, FL
    how do you know you're not getting spark or fuel to the motor?
  3. #3 Re: 2005 grand prix wont start
    Richmond,MO
    i hooked up a timing light to a plug wire and a pressure gage to the fuel rail
  4. #4 Re: 2005 grand prix wont start
    Niagara
    Could be your ICM
  5. #5 Re: 2005 grand prix wont start
    Donating Users Mikey's Avatar
    Apr 2009
    Virginia Beach
    Check your BCM. I've seen were a body control module fail and totally disabled the car.
    A buddy of mine got bumped in the rear at a parking lot (he did not know it til he got out and inspected his car) But it would not start.
    So he took his battery cables off his battery and connected the + cable to the - cable and grounded out the entire system for 15 min. It cleared his computer & drained all caps in the cluster.
    Then reconnected the cables back to the battery and it started right up.
    Worth a try if you have no other things to try.
  6. #6 Re: 2005 grand prix wont start
    Richmond,MO
    I had the local auto parts store check the ICM and its ok.I also hooked the battery cables together and still wont start.If anybody has any other ideas please let me know
  7. #7 Re: 2005 grand prix wont start
    Apr 2009
    Virginia Beach
    This is from my Alldata account on my'01 GT
    "When the ignition switch is placed in the Start position 12 volts is supplied through the Park/Neutral Position Switch to the S terminal of the Starter Solenoid. Ground is found through the engine block."
    Then check Theft deterrent control module
    Hope this helps.
  8. #8 Re: 2005 grand prix wont start
    evansville, in
    Did you check out your cam shaft position sensor?
  9. #9 Re: 2005 grand prix wont start
    SE Level Member Freimuth's Avatar
    Nov 2009
    Clinton, Ohio
    Sounds like a sensor to me also.
    New to me ---- 1999 Grand Prix GTP 216K miles and counting
    SOLD----1997 Grand Prix SE 3.8 -- 1K miles from the 200k club.
  1. 98 Grand Prix GTP wont start...
    By keioffice in forum General Tech Discussion
    Last Post: 02-01-2010, 04:13 AM
  2. 2005 grand prix gxp trans
    By guy87 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-01-2009, 11:06 PM
  3. 96 grand prix 3.1 wont start cold
    By oldtruckluvr in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-17-2009, 08:51 AM
  4. My New 2005 Grand Prix
    By extreme in forum 04+ Specifics
    Last Post: 08-10-2009, 10:18 AM
