Thread: What's normal operating temperature in traffic?
Results 1 to 4 of 4
  1. #1 What's normal operating temperature in traffic?
    GT Level Member Z28's Avatar
    Oct 2008
    Omaha, NE
    I notice the car runs a bit warmer than it usually does. It's only about 70 degrees out so far and the car creeps around 210. Is this normal for this engine?
    Should I replace a thermostat? I'm talking stop and go traffic here, it does fine on the highway.
    I should also mention, the trans is slipping a bit when the car is warm? How hard is it to drain the fluid? Just find the pan and replace the filter and fluid for now?
    Thanks guys
  2. #2 Re: What's normal operating temperature in traffic?
    Charles City, IA
    Yup drop the pan and swap the filter. 210 seams about right for stock. My car runs about 190 in heavy traffic with a 180 tstat. You could go ahead and swap the thermo anyways tho its about $8 and 2 min of work.
    SMGPFC Two Nipple General
  3. #3 Re: What's normal operating temperature in traffic?
    Willoughby, Ohio
    since there is no airflow the temp will creep up, i just click the heat on to number 1 and it usually keeps the engine cooler
  4. #4 Re: What's normal operating temperature in traffic?
    Oct 2008
    Omaha, NE
    Should be pretty simple, thanks guys...
  1. What is the normal engine temperature?
    By noname in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-14-2010, 07:37 PM
  2. Operating Temp????
    By reaper55 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-12-2010, 08:56 PM
  3. Normal Running Temperature
    By gorps in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-16-2010, 09:06 PM
  4. Engine Temperature Normal Range...
    By Chris in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2009, 08:17 AM
  5. Transmission operating pressures
    By Sabrewings in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-06-2008, 10:35 PM
