I recently installed a catless downpipe from zzp. After installing it my valves started rattling. I've tried different brands of gas but it doesn't help. Can someone tell me what's up?
You sure its the valves? That seem like an odd result to the installation of a down pipe.
I would agree it's a big coincidence that a rattle occurs just after exhaust work (and if it's valves making the noise you have a failure as they have no moving parts, they are the part that moves inside the head)
It is possible that by replacing your original, double walled DP with a single wall, you just hear your "normal" valvetrain noise more.
either that, or the gasket didnt seal well at the rear manifold.....
i had ticking from there wen my d/p was loose.
oh and the egr tube at the manifold, too.
