Thread: n/a gp gt need some suggestions
Results 1 to 15 of 15
  1. #1 n/a gp gt need some suggestions
    SE Level Member kyleheine298's Avatar
    hospers iowa
    ok i have a 99 gp gt i have msd coilpacks, taylor 8mm wires with ac plugs, an aftermarket cheapy intake, zzp stage one alternator voltage booster, glass pack instead of a resignator, n straight pipe from there on. i need some ideas and suggestions on how to get more power and make her move a lil faster.
  2. #2 Re: n/a gp gt need some suggestions
    Kansas
    HV3 and Tune and Down Pipe and Cross over and Plog and Turbo and Top Swap and Ported TB and Cam and Rockers
    SOLD 1999 GT Silvermist TS
  3. #3 Re: n/a gp gt need some suggestions
    Jersey
    do you want to spend <5
    do you want to spend >5
    how much?
    16' wrx sti- stock
  4. #4 Re: n/a gp gt need some suggestions
    GTX Level Member cerick08GP's Avatar
    #1 HV3 insert from ZZP, it’s the best "easy" mod I know of for a N/A GP. It is easy to install and gives a very noticeable HP gain above about 4k. The only down side is it costs $200.
    #2 A tuned PCM, there have been a hundred threads on which ones are “good”. But honestly with an N/A engine the differences are probably very minor. Just be aware that with a tune comes the need for premium gas. Also, all/most of the standard tunes assume you have gone to a 180F t-stat. But IMHO I’d pop for the stock t-stat option for the tune. But again, pros and cons between t-stats is another age old discussion.
    #3 Do more exhaust work: a U-bend delete and have your front exhaust manifold ported or install the PLOG from ZZP.
    If you get all three done and want more, I’d look to the valve train.
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  5. #5 Re: n/a gp gt need some suggestions
    Troy OH
  6. #6 Re: n/a gp gt need some suggestions
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    well my car ran a 16.5 stock i did down pipe plog hv3 and a cone filter and ran a 15.4 but if you have tune u could get 15-15.2 time which is not bad
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  7. #7 Re: n/a gp gt need some suggestions
    GTX Level Member Rather B Blown's Avatar
    Dec 2008
    London, Ontario
    Quote Originally Posted by nascartech View Post
    thats pretty impressive. you dropped more than a second off your et with some exhaust work and an hv3
    Quote Originally Posted by Reptile
    It sounds like you accidentally stuffed a midget in the downpipe, and he's hammering out an SOS to get out.
  8. #8 Re: n/a gp gt need some suggestions
    Topeka, KS
    Still slow IMO. Sell your MSD coils and go back to stock so you can afford some mufflers. I'm sure your car doesn't sound good at all with one glasspack and no mufflers.
    MSD coils are a waste of money when the stockers provide more than enough spark.
    As for performance gains. Do a top-swap or go Turbo because no matter how much you mod a GT motor it's still a GT & still slow until you boost it.
    I'm not trying to disappoint or pick on ya I'm just stating the truth and giving you options.
  9. #9 Re: n/a gp gt need some suggestions
    ya i was surprised i picked up over a second im gunna get an overkill ecu and i have l67 tb and injector wich i got for 30 bucks its nice when u car run with a mustang and u have a v6 lol
    sold 97 GTP stock
  10. #10 Re: n/a gp gt need some suggestions
    Donating Users suprchrgd's Avatar
    Noblesville, In
  11. #11 Re: n/a gp gt need some suggestions
    Quote Originally Posted by suprchrgd View Post
    Sorry for the thread jack but I want your car.
    Kthnx
  12. #12 Re: n/a gp gt need some suggestions
    Troy OH
    agree with blue. i also posted a link to your for sale thread in a different guy's thread asking more or less the same thing
  13. #13 Re: n/a gp gt need some suggestions
    Noblesville, In
    Quote Originally Posted by Poil336 View Post
    thanks...
  14. #14 Re: n/a gp gt need some suggestions
    Troy OH
    if it's still around at the end of the summer, i might just have to talk to you about it haha
  15. #15 Re: n/a gp gt need some suggestions
    hospers iowa
    alrite n yeah i know its only a gt i didnt get it to go fast i got it cuz i like the look of it n sounds good with a systm n plus needed a family car for my daughter but thanks everyone for the tips
  1. ok any suggestions?
    By uNda6gT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-21-2009, 01:04 PM
  2. Rim Suggestions
    By stoner17971 in forum Tires & Wheels
    Last Post: 07-11-2009, 04:21 PM
  3. would like some suggestions...
    By Ramondo411 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-20-2009, 04:27 PM
  4. suggestions on fix, please?
    By killbill in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-03-2009, 07:38 AM
  5. Need Suggestions.
    By Dboy23 in forum Visual/Body Modifications
    Last Post: 12-27-2008, 05:41 PM
