This is kind of a dumb question but I keep going back and forth. I have ported front and rear manifolds, hv3 insert, 180 t-stat and a few other things i can't remember. Do I need a 3 inch dp or am I fine with a 2.5 dp
^^ X2
In my reading here and many other resources N/A engines seem to in general like a bit of back pressure. Unfortunately it seems to be a magic un-documented value for literally each car. IMHO you seem to have already achieved a good setup, going to super low restriction setup many not net you any gains.
Unless your going to put a ported TB, rockers, or a cam...then just keep whatcha got...although the 3" will flow a bit more, but probably not enough for you to notice.
thanks
You do mean that you have an aftermarket 2 1/2" DP I hope and not a stock 2 1/2" OD DP ?
i have a 3 inch DP from zzp 304 ss if u decided u want to go 3 inch
i got a hogan racing 3 inch catless u bend less dp listen to killa go 3 or nothing
i bought a new zzp 2.5 cat dp and my buddy was tellin me i needed a 3 but i wasnt sure because its a gt but eventully ill get a 3
2.5" isn't BAD for an N/A car...someone will probably bring up backpressure needed blahblahblah...but 3" won't hurt it either...it'll just especially help with the flow when you get more valvetrain mods or other meaningful bolt-ons...like a blower![]()
