Thread: HELP
Results 1 to 5 of 5
  1. #1 HELP
    SE Level Member davidl25's Avatar
    Apr 2009
    evansville in.
    I need HELP. Im chasing a problem that I cant find. I have a 98 GP GT. When its cold it runs great. But when warm it will buck and pop through the intake. I have tested the fuel pump and fuel regulator. Replaced the MAP, and tested the MAF. HELP what else could it be. When its warm it will cruse good but any exceleration is when it starts the bucking and poping. Please Help. Thanks David
    99 GP (SE) GT Clone, KYB AGX struts + SSC springs, GMPP sway bars, GMPP trailing arms, OTTO strut tower brace,Big 3 mod, Stage 2 voltage booster, alt rewire, 180 t stat, HID conversion, D/S rotos and ceramic pads,cold air intake, and an insane car audio setup 150+ db.
  2. #2 Re: HELP
    GT Level Member djrepoman's Avatar
    columbus ohio (polaris)
    Mine did the same thing last week, tested everything and found the pigtail for the maf sensor was bad. According to gM this is quite common as they sell a lot of these
    2000 GT ,E85 powered, and still slow
    98 GTP Stock
  3. #3 Re: HELP
    GTX Level Member cerick08GP's Avatar
    Well, it could be a few items I would get it scanned tomorrow. Anyway I’ll give you a couple ideas.
    First, my gut tells me you might just have a little water in your gas. If the problem magically goes away after your next fill up, that was it.
    My second guess is your spark plugs. It just takes one bad plug to run like $hit. Or a related item like a bad wire or coil.
    Good luck.
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  4. #4 Re: HELP
    Apr 2009
    evansville in.
    Quote Originally Posted by djrepoman View Post
    Hey man how did you test to find the plug bad.
  5. #5 Re: HELP
    Apr 2009
    evansville in.
    Quote Originally Posted by cerick08GP View Post
    Good luck.
    My buddies shop is going to scan it for me. It has been doing this for about two weeks. plus I get gas at the same place every time. If its plugs it should have a mis to it and I dont.
