Thread: What goes here?
Results 1 to 15 of 15
  1. #1 What goes here?
    SE Level Member trailshredder's Avatar
    Feb 2009
    Central Ohio
    What goes here? See arrows to bracket and Plug
    Look At pictures by houghtby_photos - Photobucket
    02 Grand Prix GT, Silver with all options.
  2. #2 Re: What goes here?
  3. #3 Re: What goes here?
  4. #4 Re: What goes here?
    Feb 2009
    Central Ohio
    Would it run without that? Have had the car over a year without it.
  5. #5 Re: What goes here?
  6. #6 Re: What goes here?
    Feb 2009
    Central Ohio
    [QUOTE=Bio248;327138][IMG][/IMG]
    Hey Bio, thanks for posting those. For some reason, I can't upload pics so I been using photbucket. Any ideas what I might be doing wrong. Pics were reduced to a smaller size.
  7. #7 Re: What goes here?
  8. #8 Re: What goes here?
    Feb 2009
    Central Ohio
    take the picture location (http://xxxxxxxxxx..../yourpicture.jpg) and put it in between [img] and [/img] tags.
    thanks
  9. #9 Re: What goes here?
    Feb 2009
    Central Ohio
    didnt you just answer your own question?
    guess so ... lol
    Why would it not be there? Previous owner bypass for something. Is it for sure the MAP sensor?
  10. #10 Re: What goes here?
    GTP Level Member Scimmia's Avatar
    QCA, IA
    It is most definitely not the MAP sensor. The MAP sensor is in the UIM on the L36. I'm trying to remember what might be there.
    2001 Buick Regal LS - Almost Stock
  11. #11 Re: What goes here?
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    I'm wondering about this too! I'm almost done doing my SS M90 install, and I can't figure out where that connector goes...
  12. #12 Re: What goes here?
    Feb 2009
    Central Ohio
    Quote Originally Posted by Scimmia View Post
    Found this online. Called a secondary air injection solenoid? Not sure what it does and why I don't have one though!
  13. #13 Re: What goes here?
    QCA, IA
    That explains why I couldn't think of anything, either. The secondary air injection system is part of the California Emissions package. If you don't have that package, you won't have anything there.
  14. #14 Re: What goes here?
    GTP Level Member SuperSport's Avatar
    Michigan
    I have the same empty plug and bracket as you. I have an 01 GT. I just assumed it had to do with something for California or a block heater. I never worried about it.
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  15. #15 Re: What goes here?
    GTX Level Member imdaman3's Avatar
    Feb 2010
    ohio
    nuthin goes there, they used same harness for yrs thats for the old evap solinoid now extended its in the front for the newer 3.8, so it not used they did that thinkin thats what caught fire if it had a leak cuz of the heat between fire wall and rear maniflod then they moved it in the front (less heat) but needless to say that wasnt tha problem
