****! I'm getting more misfires. They are random and are jumping around to nearly every cylinder. Could it be the coil? Can I replace my GTP coils with my GT coils ontop of the coil bracket plate, or are the coils different altogether? By the way, my fuel pressure is sitting around 45 psi at idle.
What are you scanning with? Any way you can post up a scan? I don't think 1 wire is your issue, i think its either multiple wires/coils or running way too rich, possibly due to the wrong ifr tables in the pcm or wrong maf table? I would not drive it or rev it until it idles well.
Switch the whole ICM+coil packs from the gt to the gtp.
What's your cat looked like? My old one was horrible and that picture looks like that black **** that came out of it when I took it off.
Did you ever chck the vac lines? That would make it run rich.
Replaced the coils and ICM, didn't help it. Can I just keep these coils and ICM on, or should I change them back to the GTP ones? I don't think it makes a difference. I'm having trouble identifying if there is a vacuum leak or not.
Well the engine goes into closed loop 30-60 sec after startup. But you are scanning, what does the 02's read? It might read or stay at a constant number if it was bad.
Not necessarily saying the intense tune is junk, somethings not right. It seems like its dumping way too much fuel. Where did you get this pcm from? Directly from intense? What year was it for? What year of maf are you using?
I'll have to read the O2 reading tomorrow. What should it be, approximately?
I got the PCM directly from Intense. He asked what I was doing and what mods I had done. I told him everything I was doing to it. It's for a 2001 Grand Prix GT. The MAF sensor in my car is stock, I haven't changed it.
What kind of fuel pressure regulator did you use.
