Thread: Tac Module
Results 1 to 2 of 2
  1. #1 Tac Module
    SE Level Member Skeeve's Avatar
    carneyville FL
    What is it and where is it located? i've been doing some research into my problems, and saw one post on some other site that mentions a problem with the tac module and the pcm that will cause "Reduced Engine Power Mode" which will lead to
    Acceleration limiting--The PCM will continue to use the accelerator pedal for throttle control; however, the vehicle acceleration is limited.
    Limited throttle mode--The PCM will continue to use the accelerator pedal for throttle control; however, the maximum throttle opening is limited.
    Throttle default mode--The PCM will turn off the throttle actuator motor and the throttle will return to the spring loaded default position.
    Forced idle mode--The PCM will perform the following actions:
    Limit engine speed to idle by positioning the throttle position, or by controlling the fuel and spark if the throttle is turned off.
    Ignore the accelerator pedal input.
    Engine shutdown mode--The PCM will disable fuel and de-energize the throttle actuator.
    the last one sounds a lot like the problem im having
    99 Grand Prix GT
  2. #2 Re: Tac Module
    carneyville FL
    wow... no answer on this one?
    99 Grand Prix GT
  1. abs module
    By tlaloczint in forum Brakes/Suspension/Chassis
    Last Post: 02-20-2010, 11:43 AM
  2. 04 gt abs module on a 04 gtp will it work?
    By 98gtp1000 in forum 04+ Specifics
    Last Post: 10-29-2009, 05:37 AM
  3. 04 gt abs module on a 04 gtp will it work?
    By 98gtp1000 in forum Brakes/Suspension/Chassis
    Last Post: 10-14-2009, 10:26 PM
  4. Module?
    By GTPluv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-22-2009, 05:16 PM
