Thread: Loss of power since downpipe install
Results 1 to 10 of 10
  1. #1 Loss of power since downpipe install
    SE Level Member Everblades2's Avatar
    Florida
    So I bought a ZZP catless downpipe and went to have it installed today. After they finished I was driving and the exhaust was really raspy, so I went and got a resonator put back on. My problem is that it seems like I've lost some power. It just doesn't have that kick that it used to have before I put on the downpipe.
    Is there a reason for the possible power loss?
    2008 Grand Prix Base - HV3, ZZP Downpipe, Custom FWI, Dual Exhaust (Magnaflows / Magnaflow Hi-Flow Cat), 15%/25% Tint
  2. #2 Re: Loss of power since downpipe install
    Jan 1970
    Maquoketa, Iowa
    3" downpipe?
  3. #3 Re: Loss of power since downpipe install
    Florida
    No, i got the 2.5 to match the rest of the piping.
  4. #4 Re: Loss of power since downpipe install
    youre crazy because you should be making MORE power now.
  5. #5 Re: Loss of power since downpipe install
    Florida
    I thought the exact the same thing! I really don't know what's going on haha.
  6. #6 Re: Loss of power since downpipe install
    the bottleneck in your exhaust is removed, so now your powerband moved up a little in the RPM range. you are making more power, just in a different area. therefore, that low end grunt you had before is reduced for a little more top end. however, it shouldnt be a night and day difference as you dont have that much power to begin with. your head is playing games with you.
  7. #7 Re: Loss of power since downpipe install
    Grand Island, Nebraska
    i agree, most of the smaller mods like that are in your head. you might only be able to notice on the track or on a dyno.
  8. #8 Re: Loss of power since downpipe install
    Portland Oregon
    You have the hv3. That with the dp causes a loss in low end torque. I'll bet if you got a tune to take advantage of your mods then you'll be set
  9. #9 Re: Loss of power since downpipe install
    Tunes make or break these cars...get one and you'll be glad you did.
  10. #10 Re: Loss of power since downpipe install
    GT Level Member gtryda's Avatar
    Feb 2009
    Ohio
    When i had my 3 in downpipe an header install i noticed a night an day difference really opened that thing up. Maybe it could be that u losing a little bit of low end torque replacing it with more high end torque? All depends on at what point u usually step on it. I noticed a gain because i always drive on the highway so i feel it alot but if u drive on regular roads an press the gas u will notice that low end not picking up like it used too.
    A Beast In the Making
  1. overheating - loss of power
    By grand prix newb in forum General Tech Discussion
    Last Post: 06-20-2011, 10:27 PM
  2. power loss when hot
    By Juanmiguel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-30-2009, 03:23 PM
  3. loss of power to gauges
    By GTPRiley in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-22-2009, 12:58 PM
  4. power loss
    By offroadfury6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-27-2008, 11:12 PM
  5. Electrical Power Loss
    By 98gpgt98 in forum General Tech Discussion
    Last Post: 06-17-2008, 07:40 PM
