When the time comes, where can i order a tune for a N/A 06 base GP?
well. you've got a few options, overkill, zzp(not perferrably though), intense or a custom tune from someone on here.
Gotta get a different PCM...anything after '05 is screwy. Gotta get a '04-'05 PCM to get tuned.
Unless you want your gauges to read in reverse...then yes.
for a reprogammed pcm from intense, there is no 06 base option. there is just 06 gt with the L26 engine which is the same as mine. what option do i want for a n/a 06 base gp? heres the link
INTENSE-Racing.com: INTENSE™ Reprogrammed 3800 Powertrain Control Module (PCM)
I've been considering tuning as well. However, I read that zzp's tune's aren't very good. From what I read the best option for our 06's is to get an 05 pcm and then tune with hp tuner.
