Thread: N/A Advice... Heads?
Results 1 to 11 of 11
  1. #1 N/A Advice... Heads?
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    Hey guys. I'm really considering just keeping my car N/A, even though I'm on the fence with a turbo setup. The thing is, I'm a 20 year old student who really can't afford to turbo it, and possibly end up having a major repair come up later from the extra abuse my stock parts are taking. I know most of you guys are going to yell at me and tell me to at least top swap it, but I think I might just keep it N/A, and keep it my reliable DD. So far I've done the Powerlog, downpipe, and CAI. I have the HV3 insert on the way. Next will be the HVTB. From there I'll start making my way into the engine, starting with a cam. My question for you guys is... What heads would you recommend to yield the greatest performance gain, while keeping my car reliable as a DD? I know ZZP and W Body Store have a few different ones, but I don't know what to look for. Help is much appreciated! =)
  2. #2 Re: N/A Advice... Heads?
    Jul 2008
    sumter,south carolina
    whats not reliable about a top swap?
    02 GTP with mods 05 GP for DD
  3. #3 Re: N/A Advice... Heads?
    From everyone I've talked to about doing a top swap, I've basically got the same response... It's a ticking time bomb running boost on high compression. I just don't want to **** something up.
  4. #4 Re: N/A Advice... Heads?
    I just want to stay N/A I think. I'd feel better about it...
  5. #5 Re: N/A Advice... Heads?
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    zzp stage 2
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  6. #6 Re: N/A Advice... Heads?
    Stage 2?
    Pfft.
    Selliot has a set of ported and polished L26 heads for sale right now...check em out...then buy some #105 crow cam springs, titanium retainers...and get some 1.95 Roller Rockers...done. Extra 25-40 horse for your N/A car...couple that with an HV3, 3" DP, ZZP PLOG, Ported TB form Reptile, FWI, 180* and a tune...your looking at low 14's or high 13's with a good launch. That's just me though. Plus...if you tune it right and you have flow mods (eg...headers, ported blower) then a top swap isn't a ticking time bomb...it is if you try to drop pulley sizes on it though.
  7. #7 Re: N/A Advice... Heads?
    Stage 2?
    Pfft.
    Selliot? Sorry, I'm not sure who/what that is... Lol. And it's a set of L26 heads... They will work fine with my L36 block, correct? You'd recommend the 1.95 Roller Rockers over the cam?
    Thanks for the response!
  8. #8 Re: N/A Advice... Heads?
    Donating Users kfish's Avatar
    Ohio
    my top swapped car is a very reliable dd. ported blower and headers on a 3.5" and no knock.
  9. #9 Re: N/A Advice... Heads?
    Quote Originally Posted by Bedwards View Post
    He is just a member here...look in the For Sale section.
    1.95's will gain you almost as much power as a cam...ALMOST. Nothing is like going cammed. Unless your a woman and spray it.
    1.95's also only require taking off the valve covers...doesn't require taking the whole motor apart LOL
  10. #10 Re: N/A Advice... Heads?
    GT Level Member 01gtspecial's Avatar
    Apr 2009
    Georgia
    now i want those heads and rockers....cuz my car is STILL slow haha
    01 GT special ed.: SD hood, GMPP kit, poly sway bushings, Eibachs/Gabriel Ultras, Eagle GTs, ZZP anti-pogo, ZZP short dogbones, ZZP poly trans, ZZP PCM, ZZP HV TB, ZZP HV3, P&P LIM, 4" FWI, 3" DP, custom exhaust, pwdr-coated Trans Am brakes, NGK iridiums, Mobil1 Syn fluids, stage 2 voltage booster, BIG 3, real loud stereo...
  11. #11 Re: N/A Advice... Heads?
    Jersey
    since when are top swaps not reliable? This subject keeps coming up. I want proof.
    My car is a dd, has 11k on it since top swap, 5psi, 0.0 knock, and beaten all day long
    If your not using high compression for your m90 setup, your not living
    16' wrx sti- stock
  1. Need heads
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 11-09-2009, 02:50 PM
  2. Intense's S3 Heads VS. ZZP's S3 Heads.
    By pontiackid in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-15-2009, 02:08 PM
  3. Heads
    By 04BlackComp_G in forum General Tech Discussion
    Last Post: 03-31-2009, 10:59 PM
