Thread: hv3 question
Results 1 to 20 of 31
  1. #1 hv3 question
    GTX Level Member kjohnson's Avatar
    Nov 2008
    Harlan, IA and University of Northern Iowa
    Im sorry that im asking this question because im sure that the awnser is on this site but since the search button wont let me search for that word and I cant really find what im looking for for ill just ask. What is hv3? what does it do? and how do you make a n/a engine better by either replacing it or removing it.
    sorry again i just kinda wanted to know
    silver 2003 Grand Prix GT List is on it's way to be updated
  2. #2 Re: hv3 question
    the hv3 is an insert that goes on the inside of the upper intake manifold. it increases your top end considerably compared to stock because of the way it flows compared to the stock runner insert.
  3. #3 Re: hv3 question
    GTP Level Member Scimmia's Avatar
    QCA, IA
    HV3 is the third version of ZZP's High Velocity Intake Insert. It replaces the runners in the plenum with shorter ones, shifting your powerband up.
    2001 Buick Regal LS - Almost Stock
  4. #4 Re: hv3 question
    To benefit fully from it...get a ZZP PLOG and a 3" Downpipe...Let your car breathe first before moving more air.
  5. #5 Re: hv3 question
    Nov 2008
    I just replaced that a few mounths ago cause i had to replace the upper plantum. it probbly isnt the right one though is it? i got it from car quest
  6. #6 Re: hv3 question
    They also only claim 30 HP if you're running their ER rockers.
  7. #7 Re: hv3 question
    Quote Originally Posted by kjohnson View Post
    Replace what?
  8. #8 Re: hv3 question
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    Replace what?
    The upper plantum, brah...
    Lol.
  9. #9 Re: hv3 question
    Nov 2008
    ya sorry now that i reread that it didnt make any sence at all. my bad. I had a coolant leek right under that plantum so I got a new plantum and gaskets which included the "guts" for the inside of the plantum. im assuming the guts is what your talking about when you say hv3. its the insert that goes inside the plantum right? is there anyway of knowing if its the hv3 or is it probably just the oem one? Id like to do my down pipe but I really dont think Ill be doing to many mods on my engine since I really dont know a hole lot about em(enough to be able to replace bigger gaskets but that is about it). so real question hv3 or not?
  10. #10 Re: hv3 question
    Aug 2008
    KCMO
    if you got it from the parts store then is oem.
  11. #11 Re: hv3 question
    Nov 2008
    figures. is it only zzp that makes hv3? I really wish I would have known about this before I replaced that plantum
  12. #12 Re: hv3 question
    Aug 2008
    KCMO
    ya im pretty sure thye are the only ones that make it
  13. #13 Re: hv3 question
    Nov 2008
    makes sence. would a new down pipe still do me good and about how much do they run
  14. #14 Re: hv3 question
    GTX Level Member cerick08GP's Avatar
    Yes, the only place to buy a HV3 insert is from ZZP.
    HV3 installed in upper manifold
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  15. #15 Re: hv3 question
    Jan 1970
    Maquoketa, Iowa
    It's N/A... a plog and 3" dp is not really needed. If anything spend the money on a 2.5" dp to get rid of the u-bend and retain some low end torque.
  16. #16 Re: hv3 question
    Nov 2008
    what is the ubend ive heard of this but never really asked the question
  17. #17 Re: hv3 question
    Quote Originally Posted by FoSHO99 View Post
    I know its N/A...that's why I said what I did. I would never waste money on a 2.5" DP.
  18. #18 Re: hv3 question
    in a house
    You may be right, I don't know so that's why I am asking. Is their any actual proof that a 2.5" dp is not sufficiant for a N/A car? I see this alot on here so that's why I am asking. Im still running a stock dp with the ubend gone. I see no KR on 11 psi. What benefits would I see switching to a 3" pipe?
  19. #19 Re: hv3 question
    GT Level Member pontiackid's Avatar
    KCMO
    After the downpipe on the exhaust, GM decided to put an o2sensor in. They didn't want it sticking out to the side or below the exhaust so the created a "U" shapped bend so the sensor could sit ontop. This is a major restriction on the cars and really kills the flow. By removing it they mean the section with the "U" shape out and replace it with a straight section of piping. Can be doe pretty cheap at any exhaust shop if your not one fore tackling it yourself.
  20. #20 Re: hv3 question
    Nov 2008
    then where do you put the o2 after that?
  1. FWI(fender well intake) question. Exhaust(cat) question.
    By DJspinner in forum General Tech Discussion
    Last Post: 01-23-2010, 01:47 AM
  2. Vacume Tree question & Pcv question
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2009, 01:14 AM
  3. Question: Supercharger question.....
    By nmaponte in forum General Tech Discussion
    Last Post: 03-12-2009, 01:04 PM
