Thread: Im torn on what to Do
Results 1 to 15 of 15
  1. #1 Im torn on what to Do
    Erie, PA
    I saw this and now im torn on what to do i wanted to get 1.9 rr and a 2.5 downpipe but now i am wondering if id get more gains with a High Velocity Throttle Body for the L36 and a HV3 High velocity intake insert but im not sure of the options id need to get from zzp and keep in mind all i have is a air intake so which decision is best and would they cause more problems down the road?
    Thanks,
    Bobby
  2. #2 Re: Im torn on what to Do
    GTX Level Member Toofastgs's Avatar
    Tulsa, Ok
    get the rockers
    00' GTP 350/420 - Retired
    98' GS - Sold
    Current - Lexus ES300
  3. #3 Re: Im torn on what to Do
    PA
    Personally, I would start with the DP, then the rockers. I would imagine those two mods would show the greatest improvement.
    2001 GSE
  4. #4 Re: Im torn on what to Do
    Saraland Alabama
    Quote Originally Posted by Zef_66 View Post
    I agree, the dp first it will make the rockers and anything else work that much better
  5. #5 Re: Im torn on what to Do
    Oklahoma
    I would also have to agree. Keep in mind you got to get rid of the air you are sucking in effectively before you add more. So the down pipe would help that some, but of course the 1.9 rr's are going to add a bit more air to get rid of as well as a TB and HV3.
  6. #6 Re: Im torn on what to Do
    Tulsa, Ok
    For a GT stock exhaust is good enough to flow for 1.9"s.
    Yes DP will help.
    I would do rockers hand down first.
    Now is your ? rockers and dp VS. TB and intake?
    98' GS - Sold
  7. #7 Re: Im torn on what to Do
    Erie, PA
    yes but not an air intake
    99 GP GT coupe on Chrome 18's with a K&N air intake
    R.I.P. Firefighter Michael D. Crotty whom anwsered his last alarm on April 8, 2008
  8. #8 Re: Im torn on what to Do
    Barksdale AFB, LA
    I would do things in this order:
    DP
    TB
    Rockers
    HV3
    Somewhere in there you might want to add a Powerlog since the stock front manifold is quite restrictive. I'd do it before the TB or rockers.
    2009 Subaru Impreza WRX STI
  9. #9 Re: Im torn on what to Do
    Erie, PA
    How much HP's would all that put out and how much money is the powerlog because a shop is going to want an arm and a leg for everything
  10. #10 Re: Im torn on what to Do
    Barksdale AFB, LA
    Quote Originally Posted by wrfdff4 View Post
    Nothing you can't do in your own driveway.
  11. #11 Re: Im torn on what to Do
    Erie, PA
    you dont who your talkin too then!!!
  12. #12 Re: Im torn on what to Do
    Erie, PA
    The thing is with gas prices the way they are I cant afford putting fine tune fuel in my GP so id do....
    DP
    Rockers (with 1.9's dont have I to upgrade the valvesprings and timing chain/gears.)
    then
    HV3
  13. #13 Re: Im torn on what to Do
    SE Level Member Coogles's Avatar
    Assuming you already have a cold air intake, your next mod should absolutely be a downpipe, preferably a 2.5" example as you have been talking about.
    Next, do NOT go with the 1.9's. They are far from optimal for the L36. They provide a much narrower powerband than the ER rockers that ZZP sells, which use a specific split ratio for the non-supercharged motor. With those rockers you need 90# or 105# springs on the intake side ONLY. Optionally you can choose to use aftermarket pushrods, although they are not required.
    After that the best next modification will be an aftermarket PCM, be it through your own tuning software or from one of the vendors. The increased operating range the downpipe and rockers provide will be worthless without raised shift points. If you use an off-the-shelf PCM I would recommend getting in touch with Will @ Overkill.
    Just with those three mods plus and intake I ran a 14.9 @ 92...not bad for a L36.
    Forest Green 1998 GTP Sedan - SOLD
    VS, 3.2, TOG, GMPP Suspension, 3EP Tune
    13.179 @ 106.57 w/2.005 60'
  14. #14 Re: Im torn on what to Do
    Erie, PA
    Well with looking around the forum i think ill do..
    -2.5 dp (magflo cat + U-bend delete)
    -PEM
    -Rockers (ER or 1.9rr have no idea)
    -Aftermarket PCM (overkill)
    -HV3
    NOT AT THE SAME TIME
    then a TB but i really dont know much about this mod ill have to do some research or someone can step + isnt primium feul needed?
    My only problem is I DONT want to put primium fuel in my car im losing my mind with these ******* prices and with a PCM its recomended but not neaded from what i understand and wouldnt a tune be more expensive?
  15. #15 Re: Im torn on what to Do
    Erie, PA
    I found some 1.9 rr for a good deal im not sure if i should rush into have modded rockers on my car should i wait?
