wht valve spring do you guys suggest for the yella terra roller rockers 1.9 ratio and wht are your thought on 1.95 any good or not reliable im leaning toward 1.9 and possible head porting next year thanks
105's sounds like the right thing from what i've read. If I were you, i'd go all out with the 1.95's
thanks guys i guess its 105s
Crow 105's...not those busted ass Comp ones.
No...if you want to though, get Corvette LS7 ones.
this car is staying N/A? or eventually adding a power adder? i liked the ZZP ER rockers when i was N/A, they worked well when i switched to supercharged also
Cam is way better than rockers. Yes, you should upgrade the springs with a cam change.
You will get a lot more power out of a cam, but is a lot of work and you have to know what you are doing to install it.
^^Agreed. 6500 rpm's ftw
