Thread: Nitrous (ZEX)
Results 1 to 6 of 6
  1. #1 Nitrous (ZEX)
    Barksdale AFB, LA
    I first would like to point out that I have no experience with nitrous other than what the tuner crowd seems to make it out as some magical power adder. We did have a Impala owner put some on his L36, but that was a while ago and I can't tap him for info.
    I was looking at the Zex wet kit on ZZP. But, I want information. How does this install? How safe is the bottle in the trunk? How much for a refill? How long does one bottle last? How do you tune for it? How much tuning is required? What did I eat for breakfast? How safe is it for the motor? How large of a shot? How much power will it add?
    A lot of questions, I know. I appreciate any information as I have nothing to go on.
    2009 Subaru Impreza WRX STI
  2. #2 Re: Nitrous (ZEX)
    Saraland Alabama
    never used it on a injected car, but I have had a multi bottle setup in a couple of cars with bottle heaters in the trunk with no issues, refills vary from area to area, bottles last as long as you let them (the happy button is addictive) as for safety if you go small and follow the rules it's safe
  3. #3 Re: Nitrous (ZEX)
    I live here. UR LOSN's Avatar
    Rockford, IL
    The Zex kits are EASY to install. all the solenoids are in a nice neat little box. it also has a few fail safes built in so you dont go pop.
    it has the TPS fequency, as well as a vacuum sensor. these have to be calibrated for your vehicle...easy to do just follow the instructions.
    rule of thumb...use up to 50% of what your engine makes. L36 is 200hp...so try not to go past 100hp wet. a wet kit...you are spraying fuel in with the nitrous...VERY safe!! unlike dry.
    tuning is relatively easy...depending on the shot size..all you have to do is tak out 2 degreees of timing, or get colder spark plugs.
    yes, the bottle is safe in the trunk. just make sure you have it mounted the rigth way so the nozzle picks up the most nitrous inside the bottle.
    I would invest in a bottle heater as well...this way you ae able to use a lot more of the nitrous inside the bottle. a bottle typicaly costs 25-35.00 to fill.
    I have no idea what you had for breakfast.......cherrios?
    It will take a lot of time off your quartr mile...but depending on wheel spin, etc..it is had to accurately gauge. my guess with 100 wet...a full second.
  4. #4 Re: Nitrous (ZEX)
    Barksdale AFB, LA
    So the Zex kit is a good choice to go with then. Thanks a lot for the info.
    Any other opinions still welcome.
  5. #5 Re: Nitrous (ZEX)
    Wichita, KS
    The ZEX kits are more user friendly, and kinda-semi idiot proof. Plug and play installment. Simple to install, and simple to operate. Best bet for any beginner.
    Safe as in how? The bottle is durable, and can take a beating in the event of a crash if thats what you mean. Trust me...on that one. Mount it where you want it, and think long and hard about its location ahead of time. I mounted mine in the upper left side behind the back seat in my car. I can still get to my spare tire with out having to remove the bottle. I upgraded my plastic bottle brackets that came with my kit to a set of metal ones after I was rear ended and my full bottle broke clean off the mounts. After I was hit, the mounts were still bolted to the floor in the trunk, and the straps around the bottle were still attached to the bottle. Now...that sucker, the new metal ones are bolted in really-really good, and ain't going anywhere. I pop riveted a piece of 1/4" thick 6061 T6 aluminum to the trunk floor, then bolted the brackets to those going clear through and on into the body of the car as well.
    As said above, depends state to state. Usually is $32.00 to $37.00 here on a empty bottle. (10lbs.) Helpful tip on a good bottle fill is to bring them a "chilled" bottle. Meaning, do walk in with a hot ass bottle, instead, plan ahead, and put the bottle in your freezer for a day or two, and then take it to the refill spot in a cooler. You will get more for your money when they fill a cold bottle vs. a hot one.
    Depends on the shot your running, track passes, etc. Usually you can maybe squeeze about 10 passes out of a bottle on a small shot. I personally never run my bottle empty, if the bottle pressure drops below 800 PSI I do not run it anymore.
    Everyone is different and everyone in their own mine is right and stuck with their ways. You will here hundreds of different ways to do this. Personally, I adjust the MAF, plug gap, O2's, and timing.
    A real tuners job is never ever done. Your always adjusting your car, depending on the weather. Main thing to watch and scan for is your O2's, you want to avoid a lean condition at all times. You go lean, with the bottle...stock pistons don't like that.
    How would I know, I wasn't there. You mom kicked me out early before you had a chance to wake up.
    j/k
    I had a glass of chocolate milk myself.
    Depends if your keeping the HP shot with in a sane amount for your motors build and mods. On a stock motor, you can safely, and I use that loosely, run up to a 75 shot with no worries. Main thing is to always have a good fuel supply, and pressure, and the right timing and you will be fine.
    Not really a complete question there...but personally, I run between a 55-65 dry shot. I know my car can take more, but I don't use my nitrous as a power adder...I use it as a air cooler, to cool down the air the blower heats up.
    Depends on the shot. or the jets you use. Each jet is made different to allow so much fuel and so much nitrous in for so much horse power. My system is a dry system, so I only have one jet for the nitrous to change as I see or feel fit. Example, a 55 shot, basically means 55 more horse power. But on my jets, they have the size of the hole on the jet in numbers, so you have to read the numbers, and know what jet/hp shot your installing based off that number.
    Hope that helps ya some.
    ~F~
  6. #6 Re: Nitrous (ZEX)
    Saraland Alabama
    Quote Originally Posted by GR8racingfool View Post
    T
    ~F~
    also note the hp ratings of each shot will vary from engine to engine, and day to day (weather will effect it some) I have seen dyno runs where a 75 shot gained 100hp and where it only gained 50 hp
  1. Nitrous oxide anyone?
    By ABINOK in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-19-2008, 04:39 AM
  2. Can someone explain to me how a 2 Stage Nitrous kit works?
    By Iron Indian in forum Off Topic Discussion
    Last Post: 01-28-2008, 10:36 PM
  3. Another Nitrous Question... Dry vs. Wet
    Last Post: 01-28-2008, 03:37 AM
