Thread: Turbo camshaft
Results 1 to 6 of 6
  1. #1 Turbo camshaft
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    Hey guys. I'm eventually going to turbo my 2001 GT, but I'm doing all the basic GT mods first, since almost all of them are compatible with a turbo setup. If I install a ZZP turbo cam into my N/A engine (before it's turbo), will it increase my performance, or could it possibly do harm? I'm trying to do all this in pieces because it's so damn expensive. Thank you!
  2. #2 Re: Turbo camshaft
    Jan 1970
    Maquoketa, Iowa
    I would turbo first, then buy a cam after the tranny goes.
  3. #3 Re: Turbo camshaft
    Quote Originally Posted by FoSHO99 View Post
    Hmmm ok. How soon did you end replacing your tranny after you installed the turbo?
  4. #4 Re: Turbo camshaft
    Jan 1970
    Maquoketa, Iowa
    Quote Originally Posted by Bedwards View Post
    I lied, base kits don't really destroy trannies unless you beat on it or if your transmission was on its last leg anyway. Either way, you may find yourself happy with the power that a base turbo kit puts out. If you are going cam+turbo, at that level you are going to need a fully built tranny.
  5. #5 Re: Turbo camshaft
    Ok. Sounds good. Did you do any valvtrain upgrades when you installed your turbo?
  6. #6 Re: Turbo camshaft
    Jan 1970
    Maquoketa, Iowa
    No, the base turbo kits available from vendors will run from 6-12psi depending if your intercooled, but are safe on stock engines. When you start raising the boost, then you need to tune and go with a cam. Depending on the rest of the setup, people have run mid 11's on stock motors.
  1. Camshaft?
    By paratroopermatt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-30-2009, 08:16 PM
  2. Trouble History With Camshaft Position Sensor
    By SyntheticShield in forum General Tech Discussion
    Last Post: 06-04-2009, 01:21 PM
  3. camshaft positioning sensory??
    By goyaoboya8 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-03-2009, 07:52 PM
  4. turbo
    By grand2000prixgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-24-2009, 09:25 AM
