Thread: Need intake troque specs
Results 1 to 11 of 11
  1. #1 Need intake troque specs
    SE Level Member wildman4910's Avatar
    Florida
    Hi ya"ll, I need torque specs for the upper & lower intake for a 1998 3.8L 3800 V6. I tryed the search box and all i got was "Sorry no matches" regardless of how I frazed it. Thanks for your time.
    Dave
  2. #2 Re: Need intake troque specs
    Charles City, IA
    http://www.grandprixforums.net/f18/l...ecs-23915.html Super charger specs should be the same for your uim. I think.
    SMGPFC Two Nipple General
  3. #3 Re: Need intake troque specs
    GTX Level Member a98gtp4u's Avatar
    GEORGIA
    Also for the lim u need to follow a bolt pattern, if not u break the manifold.
    3.4 pulley, 3" catless dp (ubend deleted), 3" exhaust split to 2.5 dynomax mufflers (no res), zzp plog, 4" spectre intake, alt rewire, under/overdrive pulleys, intense pcm, 3/4" zzp tb spacer, al 104's, 180* stat, msd coils/8.5mm wires, heatwrapped crossover, flipped db's, optima red top, sunpro st boost gauge: boosting 11lbs.
  4. #4 Re: Need intake troque specs
    Charles City, IA
    Quote Originally Posted by a98gtp4u View Post
    Go from the center out. You will not break it if you do not follow it it just might not seal perfectly.
  5. #5 Re: Need intake troque specs
    GEORGIA
    I followed it by how the haynes manual said to. If not it mite not seal properly, as stated above, or it can crack the manifold. Believe me when i say it can happen, ive seen it.
  6. #6 Re: Need intake troque specs
    Charles City, IA
    You go from the inside out with the torque spec it will be fine.
  7. #7 Re: Need intake troque specs
    Florida
    Thanks for link jump 01GTP! I knew the torque had to be realy wimpy w/the plastic/rubber gaskets. I just couldn't seem to find them. Thank you again and have a good Christmas Ya'll !!!
  8. #8 Re: Need intake troque specs
    Charles City, IA
    You didnt put the plastic lim gaskets back in did ya?
  9. #9 Re: Need intake troque specs
    Donating Users kfish's Avatar
    Ohio
    i think he was talking about the plastic uim
  10. #10 Re: Need intake troque specs
    Florida
    I ended up putting a upper plenuim on it, the old one was too ate up around the egr tube to reuse. I figured I got 100k miles out of the old one so for $130 w/gaskets I couldn't go wrong.
  11. #11 Re: Need intake troque specs
    I just replaced my UIM yesterday and I paid 130 w/gaskets at advance auto. I also went ahead and replaced the LIM gasket,valve cover gaskets. I also cleaned out the ports on the LIM and cleaned the throttle body up real nice. Made a huge difference in acceleration and driving.
    Snorlax strikes again.
  1. Cam specs?
    By IndeedSS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-22-2017, 09:18 PM
  2. torque specs
    By grand2000prixgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-23-2009, 06:59 PM
  3. lim porting specs
    By DOUGLASMELTER in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-29-2009, 06:56 AM
  4. torque specs LIM
    By blowfishRus6 in forum General Tech Discussion
    Last Post: 11-11-2008, 08:31 PM
  5. Torque specs
    By kstanko in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-31-2008, 12:47 PM
