Thread: donor
Results 1 to 3 of 3
  1. #1 donor
    SE Level Member Jimmy Dodge's Avatar
    Brantford, Ontario
    if I was looking to do a top swap and I found a complete 98 (same year as my GT) would the PCM be enough to go along with the super charger, or would it need a flash/tune?
    I've heard about the pin/knock that goes along with a swap... just wondering
    thanks
    Jim
  2. #2 Re: donor
    GTX Level Member a98gtp4u's Avatar
    GEORGIA
    u need a tune.
    3.4 pulley, 3" catless dp (ubend deleted), 3" exhaust split to 2.5 dynomax mufflers (no res), zzp plog, 4" spectre intake, alt rewire, under/overdrive pulleys, intense pcm, 3/4" zzp tb spacer, al 104's, 180* stat, msd coils/8.5mm wires, heatwrapped crossover, flipped db's, optima red top, sunpro st boost gauge: boosting 11lbs.
  3. #3 Re: donor
    Brantford, Ontario
    cool, thanks
