Thread: Where should the PCM be
Results 1 to 7 of 7
  1. #1 Where should the PCM be
    SE Level Member Grandprixboy1224's Avatar
    Lapeer
    for these upgrades where in them should i get the pcm?
    1. DP 2.5 With high flow cat.
    2. Front Power Log
    3. SLP 180* Thermo.
    4. Cam
    5. HV3
    6. HVTB
    Keeping in mind that i will get heads redone after i have those installed.
    2000GP-GT|CC|8%tint|Exhaust DRT|CAI| Ordering KV5 and 10000k HID.
  2. #2 Re: Where should the PCM be
    Topeka, KS
    If you go cam and all that other jazz you'll need a tune. The PCM alone won't cut it. Your going to have your sensors going hey wire. Find a good pal with a powertuner or hp tunner.
  3. #3 Re: Where should the PCM be
    Lapeer
    im doing this stuff slowly but zzp is going to most likely install it so while they install that they can tune or put in the pcm so where it will perform like it suspose to.
  4. #4 Re: Where should the PCM be
    Erie, PA
    So your going with the cam unstead of the rockers
    99 GP GT coupe on Chrome 18's with a K&N air intake
    R.I.P. Firefighter Michael D. Crotty whom anwsered his last alarm on April 8, 2008
  5. #5 Re: Where should the PCM be
    Lapeer
    yep. produces more hp and plus im getting ported heads with the cam.
  6. #6 Re: Where should the PCM be
    Erie, PA
    How much would a tune cost?
  7. #7 Re: Where should the PCM be
    Lapeer
    75 dollars
pcm
