Thread: L67 injectors on L36
Results 1 to 14 of 14
  1. #1 L67 injectors on L36
    Barksdale AFB, LA
    Does anyone know if L67 injectors are a easy swap onto a L36. The SS M90 kit is in my future and I would rather go with L67 injectors if I don't have to splice my factory wiring harness. I have a 2004 L36. This "Bosch" connector, "EV1/EV6" mess, and whatever the other kind is confuses me. I don't remember what the connector looks like from when I did my gaskets... unfortunately.
    Any help is appreciated.
    2009 Subaru Impreza WRX STI
  2. #2 Re: L67 injectors on L36
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
    You may just need the adapters depending on which injector you have currently. THen of course update the PCM to reflect the change.
    Which injector do you have?
  3. #3 Re: L67 injectors on L36
    Feb 2008
    San Diego, CA
    I have researched this because I want to eventually put L67 injectors on my 2004 LeSabre.
    Up to 2003, L36 and L67 = EV1 injectors (easy swap; no splice or adapter needed)
    2004+ s/c apps = EV6 injectors
    2004+ L36 = Multec2 injectors
    No one makes a Multec2 to EV1 adapter. I also could not find a Multec2 pigtail to make my own adapters (although I'm not done looking).
    Your only option at this time that I know of is to splice some EV1 pigtails onto your injector wires. You will have to have your PCM programmed for the different injectors, of course.
    EDIT: nice pic above. Checking Rock Auto, it is possible that a 2004 Impala L36 came with EV1 injectors...maybe early in the year? (see pic above). If your injectors look like the EV1's above, you're golden. Otherwise, splicing it may have to be.
  4. #4 Re: L67 injectors on L36
    Barksdale AFB, LA
    I looked through my how-to pics and managed to blow it up enough to pick it out of the line up above. It is the middle one "Multitech".
    I don't know how early it would have to be to make that theory true. My Imp was built in October 2003 and has a hybrid L36/L26 (like all 2004-2005 Series IIs). That means I have the following.
    Series III heads
    Series III block
    Series III valving
    Series III bottom end (although in 2004 it was nearly identical to the Series II for the N/A version; 2005 received stronger rods on the L26 and thus hybrid L36s)
    I may scrap the whole SS M90 kit. I wanted to go F/I but I dunno anymore. Splicing all of my fuel injectors doesn't seem fun. Are there no Multitec injectors that are higher flow?? ZZP says stock L36 injectors max about 300 crank HP and I'll be over that with all the mods and a SC...
  5. #5 Re: L67 injectors on L36
    Las Cruces, NM
    It's just some simple soldering. Take your time and make sure you splice the positive to positive ad negative to negative. Then shrink tube each wire.
    Get pigtails or adapters, whatever you can find cheapest. All you need is a pigtail but sometimes you can find adapters for cheaper. Ebay is your friend on this one.
    EV1, Car & Truck Parts & Accessories, Manuals & Literature, All matching items for sale.
    or buy 6 of these:
    Home » Shop » Connectors » Bosch » Bosch Type EV1 Injector Connector MATE Connector Kit
  6. #6 Re: L67 injectors on L36
    Feb 2008
    San Diego, CA
    I found something that may be of interest to you if you really don't want to cut up your wires...
    If you were to do modded fuel rails with an SS M90 or topswap, or perhaps injector spacers with a topswap, these Multec 2 "shorty" 42 lb/hr injectors might be for you:
    Racetronix-Delphi_Injector_Sale-72s
    These are GM late model SUV stock injectors and are widely available.
    Your current injectors are 21 lb/hr as I recall. I've been looking for "long" style Multec 2 injectors with higher flow rate, but have been unsuccessful.
  7. #7 Re: L67 injectors on L36
    Barksdale AFB, LA
    Okay, . Here's adapters on ZZP's site that they say go from Multec2 to the "Bosch" style. Is that all I'd need??
    ZZ Performance
  8. #8 Re: L67 injectors on L36
    Las Cruces, NM
    Looks like it. If you wanna have adapters, I would rather have mine soldered to the harness. Less crap under the hood too.
  9. #9 Re: L67 injectors on L36
    Feb 2008
    San Diego, CA
    Quote Originally Posted by Sabrewings View Post
    ZZ Performance
    That product is mislabeled. They are EV6 to EV1.
  10. #10 Re: L67 injectors on L36
    Barksdale AFB, LA
    Quote Originally Posted by agrazela View Post
    Not doubting you, but how do you know for sure?
  11. #11 Re: L67 injectors on L36
    Las Cruces, NM
    Thats a pretty big mislabel. I would call ZZP and doublecheck.
  12. #12 Re: L67 injectors on L36
    Feb 2008
    San Diego, CA
    Because I almost bought a set off a ClubGP member who got these very same items from ZZP. I had that member post me some close-up photos of the connector ends because I was suspicious.
    I was right, they are EV6 (harness end) to EV1 (injector end) NOT Multec2 harness end.
  13. #13 Re: L67 injectors on L36
    Feb 2008
    San Diego, CA
    Quote Originally Posted by VinnieGTP View Post
    I did. Their response was, "oops, you're right." That was months ago. No change to the website yet.
  14. #14 Re: L67 injectors on L36
    Barksdale AFB, LA
    Thanks agrazela. Too good to be true, I guess.
  1. 42.5# injectors?
    By fst in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-06-2008, 02:17 PM
