Thread: Check engine light on
Results 1 to 20 of 26
CMURDAx Check engine light on 01-03-2010, 08:01 PM
gtpinsc Re: Check engine light on 01-03-2010, 08:21 PM
CMURDAx Re: Check engine light on 01-03-2010, 08:27 PM
gtpinsc Re: Check engine light on 01-03-2010, 08:32 PM
CMURDAx Re: Check engine light on 01-03-2010, 08:35 PM
CMURDAx Re: Check engine light on 01-03-2010, 09:13 PM
gtpinsc Re: Check engine light on 01-03-2010, 09:45 PM
CMURDAx Re: Check engine light on 01-03-2010, 09:50 PM
Deimos Re: Check engine light on 01-03-2010, 09:51 PM
Joe m Re: Check engine light on 01-03-2010, 09:52 PM
CMURDAx Re: Check engine light on 01-03-2010, 09:55 PM
Joe m Re: Check engine light on 01-03-2010, 10:04 PM
CMURDAx Re: Check engine light on 01-03-2010, 10:08 PM
Joe m Re: Check engine light on 01-03-2010, 10:16 PM
CMURDAx Re: Check engine light on 01-03-2010, 10:18 PM
Joe m Re: Check engine light on 01-03-2010, 10:19 PM
CMURDAx Re: Check engine light on 01-03-2010, 10:19 PM
Joe m Re: Check engine light on 01-03-2010, 10:23 PM
CMURDAx Re: Check engine light on 01-03-2010, 10:31 PM
CMURDAx Re: Check engine light on 01-04-2010, 09:22 PM
Joe m Re: Check engine light on 01-05-2010, 03:32 PM
Joe m Re: Check engine light on 01-05-2010, 03:41 PM
CMURDAx Re: Check engine light on 01-05-2010, 10:48 PM
CMURDAx Re: Check engine light on 01-05-2010, 10:59 PM
Joe m Re: Check engine light on 01-06-2010, 04:51 PM
CMURDAx Re: Check engine light on 01-06-2010, 10:11 PM
  1. #1 Check engine light on
    GT Level Member CMURDAx's Avatar
    Toledo, Ohio
    So over summer my car threw a code saying the bank 1 o2 sensor was bad. mileage was bout 10mpg. found out it was the one after the cat. changed it and everything was going smooth, mpg went normal. recently it threw the same code again and my milage didnt really get bad but not as good as it was. had it scanned said the same thing again. changed it last week, had the code erased, stayed off for a week with good milage. today light came on and i took it to autozone and it threw the same code again twice, said "bank 1 oxygen sensor below threshhold". would that be the o2 in the u-bend? this is the 3rd o2 sensor im on and dont wana drop $$ to have it happen again. heard a clogged cat could be eating the sensors. is there anyone who knows what o2 i need to change or how to unclog a cat beside buying a new dp?
  2. #2 Re: Check engine light on
    Jul 2008
    sumter,south carolina
    u can take the dowpipe off and run a breaker bar or soemthing through the CAT and clear it out... do u have a aftermarket DP with high flow cat by chance?
    02 GTP with mods 05 GP for DD
  3. #3 Re: Check engine light on
    Toledo, Ohio
    no my car is stock minus a CAI.
  4. #4 Re: Check engine light on
    Jul 2008
    when its dark outside... drive the car for awhile then look underneath and see if the DP/CAT is glowing.
  5. #5 Re: Check engine light on
    Toledo, Ohio
    mkkk. im bout to go try that because my cars already kinda warm
  6. #6 Re: Check engine light on
    Toledo, Ohio
    ok so i just drove my car for bout 20 mins (it was already warm). headers werent glowing and neither was the dp/cat. i think its plugged but not bad becuase sometimes my car chugs along but not always. how hard is it to get your dp out?
  7. #7 Re: Check engine light on
    Jul 2008
    pretty easy, if anything the bolts will be kinda hard to break loose.... if they are get some PB blaster and soak them down. 4 bolts total.. 2 up top 2 down below.
  8. #8 Re: Check engine light on
    Toledo, Ohio
    mkkk ill try this tommorow and hopefully itll help. so just take a bar and like jam it through and wiggle it around? no special techniques lol?
  9. #9 Re: Check engine light on
    GTX Level Member Deimos's Avatar
    iowa
    dude seriously use freeze off. It's better than wd 40, pb blaster, and liquid wrench
  10. #10 Re: Check engine light on
    GT Level Member Joe m's Avatar
    mesa,az
    sensor 1 bank 2 is the sensor in the uben behind the cat. sensor1 bank 1 is the one on the downpipe behind the rear manifold.
  11. #11 Re: Check engine light on
    Toledo, Ohio
    it didnt say sensor 1 or 2. just "below the threshhold". not sure if anyones seen that before.
  12. #12 Re: Check engine light on
    mesa,az
    on my list of obd2 codes there isnt one that states heated o2 sensor - below the threshold. what was the code that popped?
  13. #13 Re: Check engine light on
    Toledo, Ohio
    p0141 i believe.
  14. #14 Re: Check engine light on
    mesa,az
    p0141 is your rear sensor, bank1 sensor 2. its the one in the ubend rigt behind the cant. i would check the fuse for the o2 to make sure its ok, should be a 10amp red fuse. then get under the car visually inspect the wiring harness around the sensor make sure nothing is showing or warn out. make sure the plug is set in all the way that code usually doesnt come up because of a clogged cat. its either a faulty sensor or a short in the system or bad fuse as i stated.
  15. #15 Re: Check engine light on
    Toledo, Ohio
    im gona have to check the fuse. the o2 is literally not even a week old. and the one before it was like 5months old. which box is it in, under the hood or in the glove box?
  16. #16 Re: Check engine light on
    mesa,az
    um id like to say in the hood. if not id just check the one in the glove box to lol
  17. #17 Re: Check engine light on
    Toledo, Ohio
    mk thanks. ill update ya guys tommorow
  18. #18 Re: Check engine light on
    mesa,az
    yea let us know and if i think of anything else ill let you know. oh and fyi just to let you know that rear sensor from auto zone is about 78dollars. and if you do end up replacing it again rent the o2 sensor wrench makes life easy
  19. #19 Re: Check engine light on
    Toledo, Ohio
    yeh this ones from autozone. last one was from murrays i think. ive mastered gettin em on and off with a regular wrench sadly
  20. #20 Re: Check engine light on
    Toledo, Ohio
    hey joe whats that fuse called? me and my dad looked in the manual and on the boxes and no "o2 fuse"
  1. Check engine light
    By Hawk656 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-16-2009, 04:13 PM
  2. check engine light goes on and off!!
    By stanggreg90 in forum General Tech Discussion
    Last Post: 06-19-2009, 12:37 AM
  3. Check Engine Light
    By WHITE02GTP in forum General Tech Discussion
    Last Post: 10-08-2008, 10:31 PM
  4. Check Engine Light
    Last Post: 09-01-2008, 09:01 PM
  5. Check Engine Light
    By probuilder1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-27-2008, 08:28 PM
