Thread: Pcv valve location?
Results 1 to 4 of 4
  1. #1 Pcv valve location?
    Virginia
    I have a 04 pontiac grand prix gt, and i want to know if you guys know where the pcv valve and the brake booster line is? If you have pics of the location, please share.
  2. #2 Re: Pcv valve location?
    SE Level Member nault31's Avatar
    Southside Chicago Suburbs
    Check out this link for the PCV Valve in a 97 GT, it's in a different location than the supercharged version. I will assume it is in this location for your 04.
    MACGP
    ^^I realize a stock L36 is not as fast as the sticker implies, but this sticker has worked and it is still a hell of a lot of fun to drive considering it's a grocery sedan.
  3. #3 Re: Pcv valve location?
    there is a flat cover on top of the blower towards the rear closer to the throttle body side. its in there.
  4. #4 Re: Pcv valve location?
    GTX Level Member cerick08GP's Avatar
    Just confirming nault is spot on, best write up I have seen on a PCV valve replacement actually. Trying to find the PCV valve is not an uncommon question, but asking where the brake booster line is? Give us a break
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  1. Schrader valve location?
    By malowe in forum 3.1L V6 (LHO/LG8)
    Last Post: 08-18-2009, 12:40 PM
  2. A/C compressor control valve location?
    By PCweber in forum General Tech Discussion
    Last Post: 08-11-2009, 08:25 PM
  3. GTP PCM location
    By razoredge in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-16-2008, 07:36 PM
  4. pcm location
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 04-08-2008, 03:46 PM
  5. Location of PVC Valve
    By stlmo_gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-31-2008, 08:49 AM
