Thread: mass airflow sensor issue,
Results 1 to 8 of 8
  1. #1 mass airflow sensor issue,
    ua
    the car would stall at idle, it would some times surge, i got an error code that sayed change mass air flow sensor, so i disconected the sensor and it ran enough to get by i put the sensor in and it ran better for a few days, then it died one evening and the only way to get home was to disconect the sensor. i still get a code to change the tps but that does not make sense. please help
  2. #2 Re: mass airflow sensor issue,
    ua
    oh car is 1997 with 3800
  3. #3 Re: mass airflow sensor issue,
    ua
    code p0102, 108 and 121, will start and idle but touch the gas and it dies
  4. #4 Re: mass airflow sensor issue,
    Feb 2009
    staven
    Did you fix your car yet? Mine is starting to do the same proplem
  5. #5 Re: mass airflow sensor issue,
    GTX Level Member Rather B Blown's Avatar
    Dec 2008
    London, Ontario
    Quote Originally Posted by will54768 View Post
    im confused did you put a new maf sensor in or just plug the old one back in?
    Quote Originally Posted by Reptile
    It sounds like you accidentally stuffed a midget in the downpipe, and he's hammering out an SOS to get out.
  6. #6 Re: mass airflow sensor issue,
    ua
    put a maf in, well it was bad, put a second one in and it helped but still stalls a little at a full stop so gona keep trying, ill update with any codes i find tomorrow.
  7. #7 Re: mass airflow sensor issue,
    SE Level Member Skinny J's Avatar
    Kansas City, MO
    Could possibly be a dirty or sticking IAC. Try taking it out and cleaning it good along with the port it goes into. IACs control the air bypassing the tb at idle or at a stop, if it isn't opening all the way or not at all it will cause your car to run rough or die at stops. Just something to check...
  8. #8 Re: mass airflow sensor issue,
    Wait...you said the code was for a faulty TPS but you changed the MAF? That is what I got out of the first post. If so...CHANGE THE TPS
  1. mass air flow sensor?
    By Bakerdd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-27-2012, 10:35 AM
  2. Mass airflow sensor troubles!
    By Bruty74 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-06-2009, 03:33 PM
  3. Where is mass airflow sensor on 3800?
    Last Post: 11-18-2008, 11:10 PM
  4. Mass air flow sensor
    By duane9586 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-03-2008, 01:36 PM
