hopefully someone out there is having this trouble...
i've got a '02 3.8L with 270k miles on it and haven't had any troubles up till now, literally as in i bought my first set of plugs last week i'm hoping to hit half a million miles before I retire her... currently it's having troubles and I'm running out of guesses... up hill or any time you push down more than half-way on the gas, the engine cuts out as if it's missing if you try and floor it going up hill it's almost as if the transmission dis-engages and the motor sputters, oh and the SES light flashes!... so far i've tried blaming the plugs (all are firing proper and no more "service engine soon" light, the EGR valve (poured in some sea foam stuff into the vacuum line and it cleared the stuck SES light) and the transmission (i only hope it's not the trans)... new blames are: this weekend I'm going to pull the EGR valve (that appears might be leaking?) and see what i can figure out on it... also might try and get it into a shop to have them check the fuel pressure coming out of the fuel pump...
PLEASE PLEASE if anyone has any suggestions, i'm so proud of this car rolling over 200,000 miles I hate to see it biting the dust before it hits 300,000 miles!
