same as title im a newbie
Click the link in my sig.
CAI
Exhaust Work-Depending where u live and smog laws or if u even care
HV3
Somewhat inexpensive and easy mods to start with.A good tune helps alote
guess just depends to what extent ur looking to go options are endless
well what is your goal do u want it to be just a little quicker do u want fast it all depends u can do a plog dp hv3 tune poly dog bone mounts and a cone filter and pick up a second or more in the 1/4 mile thats what i did before i top swaped whent from 16.4-15.2 all n/a on stock tune with tune and rockers u would break into 14s so same speed as stock gtp maybe a little quicker or u can save and top swap go 14.8 and faster all depends on how much you wanna spend how long ur keeping the car and how fast u wanna go but before u decide id would start with exhaust since its not a wate if u decide to top swap get some speed daddys or atleast a dp
I would say replace all the standard wear items and get everything 100% and go from there. If you don't have a good solid base to start with then mods will just make it that much more expensive when things start breaking.
I would save up for a new trans if you can. It's not an "if" with these cars, its "when"![]()
