Thread: 99 GT Misfire on cyl 6.
Results 1 to 6 of 6
  1. #1 99 GT Misfire on cyl 6.
    Nov 2009
    clarkston, MI
    Hello everyone,
    I have a 99 grand prix gt with the 3.8. What is going on, is that when the fuel tank hits 1/4 tank, the car will run roughly, making the Service Engine Soon light will blink and then go solid ON.
    I took the car to Auto Zone to get the code read. While he was hooking it up, his was thinking evap code. It wasn't.
    It was a Cylinder Misfire on #6. The guy thought it might have been a sticky injector since it is intermittent. Or maybe a plug or wire.
    Any other ideas, or should I start with the injector, plug and wire?
    And if it is an injector, what's the cheapest way to fix/clean it? I tried the in-tank additive and it doesn't help.
    Thanks!
  2. #2 Re: 99 GT Misfire on cyl 6.
    GTX Level Member a98gtp4u's Avatar
    GEORGIA
    if its the injector just replace it. start with the cheapest thing 1st then go with the injector if need be.
    3.4 pulley, 3" catless dp (ubend deleted), 3" exhaust split to 2.5 dynomax mufflers (no res), zzp plog, 4" spectre intake, alt rewire, under/overdrive pulleys, intense pcm, 3/4" zzp tb spacer, al 104's, 180* stat, msd coils/8.5mm wires, heatwrapped crossover, flipped db's, optima red top, sunpro st boost gauge: boosting 11lbs.
  3. #3 Re: 99 GT Misfire on cyl 6.
    Quote Originally Posted by a98gtp4u View Post
    X2
    plug, wires, injector
  4. #4 Re: 99 GT Misfire on cyl 6.
    Nov 2009
    clarkston, MI
    I'll start there. Thanks for the help!
  5. #5 Re: 99 GT Misfire on cyl 6.
    Charles City, IA
    Check the fuel pressure when your tank is low. I bet you have a week fuel pump and you are losing pressure since this happens when it is low.
    SMGPFC Two Nipple General
  6. #6 Re: 99 GT Misfire on cyl 6.
    Donating Users ARFF22's Avatar
    NEW YORK
    Does you car have those aluminum heat shields with the springs around the spark plug wire boot? Mine did and one of the wires on my car just kept wiggling a little loose and which caused the wire to arc through that metal heat shield causing it to ground out and run like crap. Also caused my SES light to come on once and a while. I finally just removed that heat shield from that wire because it always happened at the most inconvenient times. Best way to check for it is at night, pop the hood and look down the at the spark plug boots, you will hear and see the spark. But don't try to push the boot on with the car running, I found out the hard way. The spark coming out of that wire has a little kick to it! Cheap easy check that won't cost you anything but time. Good luck!
  1. 97 GTP Misfire
    By ThePrimerSuspect in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-29-2009, 10:42 AM
  2. Need help with misfire 98 gtp!
    By Viperhunter in forum General Tech Discussion
    Last Post: 10-08-2009, 02:39 PM
  3. Misfire
    By munkee in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-12-2009, 06:46 PM
  4. #5 Misfire
    By jjbskisail in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-06-2009, 02:36 PM
  5. Misfire like no other
    By MTXGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-24-2008, 10:02 AM
