Thread: Fuel issue...possible fuel pump????HELP
Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
  1. #21 Re: Fuel issue...possible fuel pump????HELP
    Banned
    New Port Richey Florida
    I had the same problem my 92 and had to have the car pushed a mile home change the egr valve clear codes and go from there.. Mine was a bad egr which fixed my problem.
  2. #22 Re: Fuel issue...possible fuel pump????HELP
    SE Level Member TAWinner23's Avatar
    Locust Grove, GA
    I have a new egr and a new fuel pressure regulator to put in tomorrow...if the weather will clear up hear in hotlanta (tornado alley this weekend). I will update on sunday...hopefully that will do it. If not then I might have to yeah blow it up...Joke of course.
  3. #23 Re: Fuel issue...possible fuel pump????HELP
    Locust Grove, GA
    Well....I changed the fuel pressure regulator and the egr and it started...for a minute then died. I restarted it and had to give it some throttle to keep it going, if I rev'd it up, it would rev up then choke out. The fumes from the exhaust when it is running are strong enough to burn your eyes. What is up? I tried to unplug the MAF sensor and restart it, it didn't seem to make a big difference, when I pushed the gas it hesitated...What should I check now?
  4. #24 Re: Fuel issue...possible fuel pump????HELP
    Locust Grove, GA
    Still no fix...posting a new thread to simplify problem.
  5. #25 Re: Fuel issue...possible fuel pump????HELP
    Jul 2011
    illinois
    Hello, I was having problems with my 2000 gtp supercharge I was told I was having transmission trouble. It was shuttering when I would slow to go around corner, or start up & felt jerking as I was driving on hiway.It finally quit on me. I left it parked and came back several hrs. later and it started. we changed the cam & crank shaft sensors, upline 02 sensor, ignition module and finally the fuel pump. still no fix, so took it to mechanic. My fuel pump ended up being bad, & his diagnosis was fuel pump & filter, air filter and plugs & wires. I'm not sure I needed to change all of the first stuff, because it seems like it came down to the fuel pump & filter but maybe some of the things I mentioned that I changed could be your problem. I know nothing much about mechanics, so these are only suggestions. I did get a reading
  6. #26 Re: Fuel issue...possible fuel pump????HELP
    While I'm sure the OP would thank you for that great information... the thread is from March of 2008.
  7. #27 Re: Fuel issue...possible fuel pump????HELP
    Aug 2013
    Aurora, CO
  1. Fuel Pump Resistor By Pass Mod
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-02-2012, 05:49 AM
  2. Fuel Pump?
    By 03BCprix in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-23-2008, 11:59 PM
